Originally posted by angerdan All computing intense development options do increase the processing time, so affect booth RAW (thumbnails) and JPG.
Easiest way to avoid is disabling them, shooting in RAW and develop the RAWs inside the camera afte the shooting. Mass edits for all images in one folder (day) are possible. Saves the time when needed and takes it when available.
I think this is a pretty good idea.
Let's look at things a little deeper then;
Let's say I have two 64gb SD cards inside the K-1, I shoot RAW (with every jpg and other RAW adjustments off) and am writing to just one card (sd 1) and not both simultaneously, just to speed up buffering and processing times.
At the end of the shoot/day I wish to now convert all the RAW files to Jpgs onto Sd card 2 (might even get away with a 64gb+32gb card combo now as I'm not duplicating RAW twice), I can let the camera 'think away' and doing this task as I drive back home etc.
Is there a way to quickly (and not manually pick away at the settings each time) to tell the K-1 that during the RAW>Jpg write to sd card 2 to use very specific parameters, a predetermined preset if you will that was 'built' before hand.
The Preset might be for example;
Custom Image>Flat>with increased sharpness and perhaps a tweak contrast or saturation (ie a custom variation of 'Flat').
Lens Correction On
Clarity +2
Something like that?
I mean I could even save those exact parameters as a User Mode if that helped, so that when it came to the RAW>Jpg push to SD Card 2, could you specify it to use 'User Mode 3' settings for the conversion/transfer?
The attraction of this post process task loses its appeal if each time you want to do a batch RAW>Jpg in camera you have tweak settings etc.
Why all of this?
It may be that I stumble upon a look or style (only possible from Jpg and not RAW of course) that is possible with the K-1 from within the body, perhaps the style suits rainy weather days etc. To keep consistent workflow/style I would choose to actually transfer the Jpgs to the PC first, and use this as 'round 1' of the culling process. Any images I find that need further tweaking due to accidental bad exposing I could then retrieve the raw file from the other SD card and salvage the shot better etc.
But as we know, doing RAW+ and writing a RAW + Jpg and to two sd cards does slow the whole 'shooting' experience down. I could also get a Jpg quickly in the field and use for social media without having to rely on RAW+Editing at home.
