Originally posted by dflorez Has anyone had any issue remotely similar?
Yes. Though my experience is different as it's not related to shutter speed but if nothing else hopefully what I share can be crossed off your fault checking list.
My situation.
I was using shutter priority AE and shooting Constant-High on the K-1 with the D-FA 150-450 at a motorcycle racing event. The conditions were overcast, I was shooting contre jour and the light was changeable though due to the cloud better than direct sunlight. My problem happened a few times and it seems to be linked to when I zoomed the lens. This leads me to draw three conclusions:
- It could be the lens
- It could be motion of the lens on the mount.
- Both of these conclusions could be wrong.
This series is one of a couple I have where I was tracking a rider with the lens out at 150mm. This was helping me acquire the subject, get AF to lock on and I would zoom in to get closer whilst using back button focus and releasing the shutter. The intent was to get closer to my subject by zooming as opposed to staying out at 150mm or being zoomed into a longer focal length and then struggle to acquire the subject and get it focused.
Here's a sequential series I captured.
NOTE: So in shutter priority AE with minimal changes to the light the results were um; noticeable?
Something of note with these images is the metadata the camera recorded for this series of images captured with the D-FA 150-450. Here's the summary:
- Image 1. FL-2520mm, ISO-800, S/S-1/1250s, Aperture-f13
- Image 2. FL-150mm, ISO-800, S/S-1/1250s, Aperture-f22
- Image 3. FL-20mm, ISO-800, S/S-1/1250s, Aperture-f5
- Image 4. FL-None recorded, ISO-800, S/S-1/1250s, Aperture-f5
I posted this problem nearly two years ago but no responses enabled me to determine what was actually happening hence I think something odd with the lens or loss of contact between lens/camera as I was zooming the lens. That other thread used to be a sticky for reporting problems with the K-1 and whilst I expect it's still around somewhere its relevance would have ceased some time ago so I'm not sure how to go about finding it or whether there's info there worth checking.
Based on my experience, which is admittedly different to yours I'd suggest you check the image metadata. I'd also reflect on whether you might have been zooming a lens or manually focusing a lens as the rotational motion might be a contributor. Or not.
Good luck with what you find out, don't forget to post your results if you get to the bottom of it.
Tas
