Originally posted by Walkingwolf So much support for the DFA 28-105, now I have a question...
If auto focus and weather sealing are NOT factors, then does this lens produce better results compared to the old A35-105? The A35-105 f3.5 has been touted as a stack of primes by many- so is the 28-105 only better in its coating and slight wider angle?
I have really enjoyed my A35-105 and am uncertain if I’d gain much by buying the DFA. Any advise would be appreciated. Thank you.
Sorry if I’m hijacking this thread but I thought the subject would be relevant.
One of the reasons I don’t have the 35-105 is that I really like having a wide end as wide as possible...
But the 28-105 does pretty well in the context of older primes. It’s obviously nowhere near as fast, but apart from a little more distortion, at f5.6 there isn’t a huge gap.
Edit: I went and shot the DFA 28-105 against my 28mm primes. I have a 28mm f2.8 Vivitar in TX mount, SMC-A 28mm f2.8, and Super-Tak 28mm f3.5 (I forgot to shoot with my Super Lentar, but no great loss, its name and funky bokeh are the only real super things about it...). I used hoods.
The Vivitar is smeary wide open, especially in the corners, and has a low-contrast look, almost a haze about it, that won't go away. In terms of absolute resolution, it's not bad at f5.6 and f8, but it isn't up to the others.
I'm really impressed at the consistency in look from nearly 60 years of Pentax with the other three... at f5.6 I would never be able to tell the difference on a real photo without the Exif.
That said, the SMC-A, which is not highly regarded, holds its own with the Super-Tak, and the extra third of a stop doesn't cost it any quality compared to the Super-Tak at f3.5.
I'm not sure if that says more about the Super-Tak, since it is over 50 years old, or about the SMC-A, since it seems to be a "meh" lens in the reviews.
And the DFA 28-105 is a little worse, maybe, at f3.5 in the center, but better in the corners... that's a hard call... it's a very good lens.
-Eric
