Originally posted by MightyMike The corner cross type points were described to me as L-shaped not T-shaped in the orientation I've provided in the image, perhaps the spacing isn't spot on but the orientation certainly is
I was just referring to the spacing of the line sensors, not how they are combined into crosses or T's or L's.
Edit:
That means that the "outer red lines" in your diagram are simply going thorugh the displayed AF points (or their outer edges).
You drew them far outside the viewfinder points, which leads to different spacing and is not correct.
And to be clear: I can confirm that the outer 14 AF points are either T's or L's.
Everyone can check this at home with a computer screen within a minute.
