Originally posted by MJKoski It would be interesting to see if upgraded model has this magenta cast. Or is it only new mk2 models. Before you upgrade, take test shot - underexpose ISO100 frame by 4-5 stops and push it back to 0EV. Then do the same with the upgraded body.
Good idea! I will do that today---I think I did not win the raffle , so it's off to the post this afternoon. I wish you the best of luck finding something that works for you. I still think you should try to return your camera, since you've amassed enough evidence that there are problems in certain cases that affect your typical use of the camera, and that these were hidden from you.
