07-26-2018, 09:27 AM - 4 Likes   #1
D1N0's Avatar
Rolling shutter effect when using electronic shutter
Your subject doesn't have to be moving. Camera movement will do it 200mm 1/500th shot on a monopod. The relatively high shutter speed doesn't prevent it.
The same shot same shutter speed with mechanical shutter:
After this I turned of electronic shutter mode in live view.
07-26-2018, 09:53 AM   #2
UncleVanya's Avatar
QuoteOriginally posted by D1N0 Quote
How much did the camera MOVE? That's crazy.
I think you'd be hard pressed to recreate that level of distortion with those exposure parameters with a steady camera.
07-26-2018, 09:53 AM   #3
So this is why electronic shutter disables shake reduction. Rolling shutter IS shake [blur] reduction.
07-26-2018, 10:12 AM   #4
reh321's Avatar
The "relatively high shutter speed" is misleading. The camera reads the sensor one line at a time, and regardless of the "shutter speed", the overall process takes something like 1/13-th second. Thus, the last line on the sensor comes from a view 1/13-th second after the first line .... and that is what causes the 'rolling shutter' effect.
07-26-2018, 10:22 AM - 1 Like   #5
D1N0's Avatar
QuoteOriginally posted by reh321 Quote
So then it is only really usefull on a tripod. It picked up the movement of the monopod in 1/13th of a second quite well. I hadn't noticed it very much before but a wider FOV's the effect will be less apparent.
This shot of the same bottle was shot hand held and also show the effect. Not a wavy distortion but the dimensions of the bottle are off in two of them, then it is wider, then it is narrower:
07-26-2018, 10:42 AM   #6
The thing is, you want to use ES to avoid shutter shock, which in my experience can occur below 1/400 shutter speeds and therefore you need to be extra carefull and should always shoot also without ES as backup, in case you did not notice any issues while reviewing on the camera.
I had problems with a 135mm lens handheld, thats when I learned that lesson .
07-26-2018, 12:32 PM   #7
Unregistered User
Guest
I had that problem when shooting fan blades, so I stopped shooting fan blades.
07-26-2018, 01:00 PM - 4 Likes   #8
Thagomizer's Avatar
QuoteOriginally posted by Cipher Quote
I told my doctor I broke my leg in three places. He told me to stop going there.
Thank you, thank you. I'm here all week.
(I'll find my own way out)
07-26-2018, 04:53 PM   #9
Otis Memorial Pentaxian
clackers's Avatar
Each pixel might have only been exposed for 1/500th second, but there's a difference of about 1/10s between when the top of the frame and the bottom were exposed.
07-26-2018, 04:54 PM   #10
clackers's Avatar
QuoteOriginally posted by Thagomizer Quote
I also heard that a man is run over in our streets every two days … it must be you!
07-27-2018, 02:37 PM   #11
That is worth knowing, thanks for posting!
dslr, full frame, full-frame, k-1, k1, pentax k-1, shot, shutter, shutter effect
Rolling shutter nobody Pentax K-3 & K-3 II 13 06-04-2018 12:16 PM
Mechanical Shutter vs Electronic Shutter... ? watchingskyfallatm Photographic Technique 6 01-11-2018 07:23 AM
Does the electronic shutter provide anything other than ultrafast shutter speeds? jake14mw Pentax KP 19 06-21-2017 04:34 AM
Problem with 1.30? Window Blind Effect Using Live View Electronic Shutter dcpropilot Pentax K-1 & K-1 II 21 10-02-2016 07:56 AM
Leaf shutter vs Electronic shutter? Ishpuini Pentax Q 8 11-14-2012 04:33 PM
All times are GMT -7. The time now is 05:41 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
