Originally posted by PJ1 I was under the impression that you could screw off the Exacta bayonet mount and replace it with an M42 mount.
That might be possible with some lenses, but probably not with CJZ. I have several 50s that I would like to rebuild and switch over, but the Exakta versions have dissimilar body construction to the M42.
Originally posted by PJ1 There is this adapter on offer:
Yes, I saw these (there is more than one vendor) early in my search for a way to use my Exakta lenses on a Pentax. I did not order because it appears that the grub screws are not long enough to engage the lens barrel, the thread lens will still take its registration from the flange on an M42 body and from either the body or adapter when adapted further to K-mount. In other words, no infinity focus. Here is a link to the same item from a different vendor with somewhat better photos.
https://www.ebay.com/itm/Pixco-Detachable-3-bit-Lens-Adapter-Ring-For-Exakta...P/273220195234 Originally posted by PJ1 The good news is that the rear projecting section is just empty space.
Not true for my Pancolar 50/2s or Flektogon 35/2.8 (Vivitar 28/2.8 either). Again, while both CZJ lenses share optics with the same lens in other mounts (M42 and Praktica-B), the lens bodies are often not shared and of course, there is still the hurdle of finding a donor M42 body. Sorry to be so pessimistic, but having taken a Pancolar 50/2 apart, I can assure you that swapping a new rear is something I quickly dismissed.
In my opinion, mirrorless is the best option for adapting Exakta glass to a modern camera.
