Originally posted by Bavand so the lens does not work in the FF mode at all and it's the same as a K-5 at any focal length?
The camera won't hinder you operating it in FF mode, but the image will be severely vignetted, so "cropping" to APS-C either in postprocessing or in-camera seems to be the most sensible solution.
You might gain a slightly larger image than APS-C, but not by much.
Besides, the optical quality of that lens won't be as good to do credit to the K-1.
Most zoom lenses degrade with high zoom factors, the 18-270 is a 15x zoom lens.
More "professional" zoom lenses don't use zoom factors above 3 or 4. The 70-200 range is 3x, the 28-105 is slightly below 4x.
It seems to be impossible to get a f/2.8 zoom with a zoom factor higher than 3.
There is a 10x zoom lens on the market which is some kind of an exception to the zoom factor/crap ratio, that is the "bigma", a 50-500 zoom, which in some markets can still be obtained in Pentax K lens mount. That one
does perform decently on the K-1, and it even comes with an optical image stabilizer. Yes, that works with the K-1 (and all other SDM-capable Pentax bodies since the K10D).
More about the "bigma" can be found here
Sigma 50-500mm F4.5-6.3 DG OS HSM Lens Reviews - Sigma Lenses - Pentax Lens Review Database
and here
Sigma 50-500mm F4.5-6.3 APO OS HSM Review - Review | PentaxForums.com Reviews
Be careful if you obtain an older copy, since that lens is one of those likely to scratch the K-1's body. On newer copies, Sigma replaced the bayonet ring with an updated construction.
This lens will give you the most "bang for the buck", but it comes with some weight - it's slightly heavier than the HD Pentax-D FA 70-200/2.8
