11-05-2018, 09:51 PM   #1
bobphoenix's Avatar
K1 with Remote Release - Auto Focus Failure
I have been using my K1 for a month now and for the first time, I decided to use it at a party where I set it up on a tripod and used an IR remote... Disaster!
Am I missing a setting somewhere...?
When I trigger the camera with the remote, the camera doesn't focus! I will trigger the flash and open the shutter, but no focus.
I even have the camera set to not fire until it is in focus too...
Any thoughts or suggestions would be greatly appreciated.
Cheers,
Bob
11-05-2018, 10:40 PM - 2 Likes   #2
In the menu, C-10 AF with Remote Cotnrol on or off. Mine is off, so I suspect the default is off.
11-05-2018, 10:58 PM - 1 Like   #3
Otis Memorial Pentaxian
QuoteOriginally posted by derekkite Quote
Yes, the default is OFF as has been the case for Pentax dSLRs for pretty much forever. The rational is that one does not want to take the risk of focus being lost to a passing bird or an element of the background with the photographer away from the camera. It might also be noted that this setting affects IR remote only. A wired remote is not bound by this setting.
11-06-2018, 08:29 AM - 1 Like   #4
Probably what has been suggested, but just in case: If you're using the O-RC1 IR remote, it uses a separate button for the autofocus function. In that case you need to hit that button first (to focus), and then the shutter release. Handy since it allows you to leave the AF with remote activated, and choose whether to autofocus or not. I believe some other IR controls work the same way.
11-06-2018, 05:11 PM   #5
bobphoenix's Avatar
Thank you all...
Yep Auto focus with remote was defaulted to off and I missed it when doing a setup... Also, I do have the O-RC1 IR remote and missed that function button too...!
It's another typical case of operator failure...
Well, it looks like we'll just have to do the party all over again so I can get it right the next time... LOL!!!
Thanks again...
Cheers
Bob
11-06-2018, 09:49 PM   #6
clackers's Avatar
QuoteOriginally posted by bobphoenix Quote
Thank you all...
Thanks again...
Cheers
Bob
I think more generally, Bob, test out a new shooting method or piece of equipment before the event!
It took less than 24 hours before this forum gave you the answer, but it's no good to you if the party's been and gone.
11-07-2018, 04:53 AM   #7
WPRESTO's Avatar
Thank you all...
Thanks again...
Cheers
Bob
Don't feel bad. Modern cameras have an instruction manual akin to the New York City yellow pages. For my first Pentax, the camera operating instructions that were required reading were hardly longer than the index in the K1 manual. And the selfie remote was unambiguous - bzzzzzz-DAP. You could see & hear it working from start to exposure
11-07-2018, 10:17 AM - 1 Like   #8
QuoteOriginally posted by WPRESTO Quote
...see 0:52...
Vintage Pentax Commercial - YouTube
camera, dslr, focus, full frame, full-frame, k-1, k1, pentax k-1, release auto focus
50-135mm sdm lens auto focus failure Rose Pentax SLR Lens Discussion 18 07-03-2023 03:53 AM
The dreaded SDM failure topic - Nikon AF motor failure perspective beholder3 Pentax SLR Lens Discussion 21 07-19-2018 10:02 PM
Suggestions for remote shutter release cable / remote Sean Hamilton Troubleshooting and Beginner Help 8 06-09-2016 07:15 AM
K1 Remote release connector K-amps Pentax K-1 & K-1 II 19 04-11-2016 09:29 PM
TriggerTrap Mobile + IR Remote = App driven remote shutter release RoyT Do-It-Yourself 4 01-02-2014 08:50 AM
All times are GMT -7. The time now is 09:19 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
