11-23-2018, 06:14 AM   #1
thepedant's Avatar
K-1 power supply for UK
I would like to buy a power supply for my K1 mk 2. The only source in the EU seems to be this one but there is a slight discrepancy between the picture and the words. The picture shows a connector for the DC in port but the words refer to a "DC Coupler (to insert in the battery compartment)". I have emailed the company to ask which one is supplied but they don't reply. Has anyone here bought one from this source and if so did it come with the DC connector or the battery compartment coupler?
11-23-2018, 06:45 AM   #2
I think that's probably a classic example of Chinglish translation. The photos are quite clear...
11-23-2018, 01:22 PM   #3
angerdan's Avatar
The DC plug which connects to the camera is the same like the one which goes into the battery dummy for the K-70 and KP.
bhphotovideo.com/images/images2500x2500/Pentax_38899_KB5232_AC_Adapter_Kit_846262.jpg
bhphotovideo.com/images/images2500x2500/pentax_38780_k_ac132_ac_adapter_kit_1008376.jpg
By the way, the one in your link isn't a genuine Pentax adapter. That's why it is cheaper than 60€.
If you don't need a copy made by Pentax, better get the same model from germany - it's even £5 cheaper.
Pentax (K-AC132,K-AC168) in Camera and Photo Accessories | eBay
Maybe some day Ricoh will start selling it own AC power supplies again.
AC adapter K-AC132E - RICOH PENTAX Store UK
AC adapter K-AC168E - RICOH PENTAX Store UK
11-24-2018, 02:11 AM   #4
thepedant's Avatar
Thank you angerdan I understand how I got muddled about this. I have ordered one.
10-10-2019, 02:16 PM   #5
angerdan's Avatar
QuoteOriginally posted by thepedant Quote
I have ordered one.
How well did everything work out?
10-31-2019, 01:27 PM   #6
Maybe check the voltage and Hz as these vary between countries. Best not buy if the company doesn't answer your emails.
battery, connector, coupler, dc, dslr, full frame, full-frame, k-1, k-1 power, k1, pentax k-1, picture, source, words
DC power supply for K-5 or -7 fewayne Pentax DSLR Discussion 4 10-20-2018 08:38 PM
AC power supply 167 for k1 II or 132 version rechmbrs Pentax Camera and Field Accessories 13 05-19-2018 03:40 PM
Cheap bench top power supply Altheim Do-It-Yourself 3 03-07-2018 07:39 AM
Help wanted: just changed power supply/ad RAM: 15 GB of SSD storage are gone ! ??? jpzk Troubleshooting and Beginner Help 30 05-09-2017 07:02 PM
Pentax external power supply voltage tolerances beholder3 Pentax DSLR Discussion 9 02-16-2017 05:56 AM
All times are GMT -7. The time now is 09:15 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
