Show Printable Version 8 Likes Search this Thread
07-06-2020, 02:46 PM   #1
File Structure
Evening,
Firstly, I know this will have been asked before and I'm sure the answer is out there but I can't find it!
I've been out tonight for my first proper hike with my lovely new K-1 and I was shooting to RAW on one card and JPEG on the other....aren't JPEGs rubbish! Anyway, when I got home I found that instead of having one folder on each of tonight's shoot, I've got about 20 separate folders. I was shooting lots of composite images of lovely waterfalls and things like that, but I'm wondering if it's really necessary or beneficial to have them stored in separate folders? Perhaps it's the only way to keep to individual shots of a composite image together. Is there any way to simplify the structure from a day's shoot though?
Thanks
07-06-2020, 03:09 PM   #2
QuoteOriginally posted by osbourne one-nil Quote
Evening,
Thanks
Don't turn your camera off?
I also think there's an applicable menu setting but I've not had mine all that long either so i'd need to look, then probably look again.
07-06-2020, 03:13 PM   #3
pschlute's Avatar
Not understanding this statement. JPEGs from the K1 are exceptionally good.
I shoot raw exclusively and produce TIFFs and JPEGs from those raw files. As all my output whether for the web or for printing is produced in the end in JPEG format, I take the opposite view, JPEGs are fantastic.
07-06-2020, 03:14 PM   #4
Yes - it will correlate to the camera turning off. I could change the setting...the battery seems pretty robust and I got the battery grip thrown in when I bought it (I've loaded it with Lithium AA batteries as a back-up). That would be a way round I guess.
07-06-2020, 03:22 PM   #5
I'd generally agree, K1 jpegs are actually nicely processed. Up until this camera I would not have bothered with them and wouldn't now except I've unintentionally imported a lot of them seeing as i now have a two-card option and don't pay attention which card I inserted for LR.
Pleasantly surprised really, but I'm still a shooter in the RAW. :0 I prefer to alter my own images. That's half the enjoyment. It not just about the destination.
07-06-2020, 03:26 PM   #6
sbh
sbh's Avatar
My K-1 puts 500 photos in one folder before it creates a new folder. It does not make a new folder every time i turn it off and on. Perhaps there is a setting for that, but I don't recall that I have changed the default setting.
07-06-2020, 03:39 PM   #7
QuoteOriginally posted by sbh Quote
Well at least one of us must have changed something in settings.
07-06-2020, 03:47 PM   #8
Hmmmm - I directly compared the RAW and the JPEG from the camera in Photoshop and was surprised to see how much more resolution there was in the RAW image. Maybe I've set the JPEG to a lower setting? I'll have a check.
I'd much prefer that, or one folder per calendar day. I shall read the manual fully when (if) I get to bed tonight.
07-06-2020, 04:13 PM   #9
pschlute's Avatar
Resolution is the same for both, 7360x4912 pixels.
As a test process a raw file using the ACR Pentax profile the same as you have set in your camera (natural, bright etc). Then point out why the JPEG from the camera is inferior to the JPEG from Adobe Camera Raw. For most average scenes they should be identical
---------- Post added 07-07-20 at 12:34 AM ----------
Interval shooting will create a new folder for each session of pictures.
07-06-2020, 04:45 PM   #10
Thanks, I’ll try that but I wouldn’t read too much into what I said. It was based on zooming in on the JPEG output and the RAW output and I simply saw much more detail in the RAW. It was just a throwaway comment. Still, I’d be interested to do as you suggest.
As for the file structure, that is as I suspected and I guess makes sense. I don’t think I’ll be using that feature as often as I did tonight but it worked a treat and, I think, means I won’t be getting an ND filter any time soon.
I can’t wait for the dark nights to return so I can try the camera’s Astrotracer capabilities.
07-06-2020, 05:45 PM - 1 Like   #11
Paul the Sunman's Avatar
K1 manual, p 105
A maximum of 500 images can be stored in a single folder.
When the number of captured images exceeds 500, a new folder is created with the number following the number of the folder currently being used. When the drive mode is set to [Bracketing], images are stored in the same folder until shooting is completed.
I'm assuming you didn't have 500 images in each folder!?
Otherwise, I can see no way to make it do what you report, unless you are somehow selecting "Create New Folder" (Spanner 3 menu) each time to turn it on, which seems very unlikely.
07-06-2020, 06:15 PM   #12
QuoteOriginally posted by Paul the Sunman Quote
K1 manual, p 105
Mine also loads a new folder every startup. I may or may not get into the menu tonite.
07-06-2020, 09:36 PM - 2 Likes   #13
QuoteOriginally posted by gatorguy Quote
It's a known bug caused by GPS corruption. Follow the fix here.
07-06-2020, 10:29 PM   #14
Evening,
Thanks
I'm a bit confused by your statement that you have 20 folders. My K-1 creates a folder for each day, and that days shots go into that folder. If shooting is done the next day, those files will be in a new folder. I believe this happens even if the camera is not turned off (new folder at midnight). I was unaware that each folder has a limit of 500 files since I have never shot that many in a single day so that was something I learned in this thread.
If you want to group shots from a single day, you would need to pop the card into a computer and create sub folders and drop the files in those, but the K-1 will only provide grouping-by-day folders - mine did that from the git-go after I first got my K-1 without my changing any menu items.
07-07-2020, 12:06 AM   #15
Morning all - thanks for the feedback. GPS hasn't been set up or activated on the camera yet so I'm not sure it could be that. I understand why a new folder might be set-up for each set of composite photos, but the structure actually shows a new folder being created each time the camera was turned on. It must be in the settings.
The camera has been updated to the latest firmware.
It's not a big deal...just a little irritant, but then I'm very irritable!
camera, dslr, folder, folders, full frame, full-frame, jpeg, k-1, k1, pentax k-1, resolution, structure
Misc Tensegrity Structure bertwert Post Your Photos! 29 04-16-2020 07:20 PM
Nature Delicate in structure eaglem Post Your Photos! 3 04-13-2020 03:34 PM
Point and Shoot Competition #129 - Structure of Stones| Titia Pentax Compact Cameras 19 12-04-2018 11:42 AM
Architecture Suspension Bridge Structure ToddK Post Your Photos! 6 11-25-2018 08:40 AM
Understanding Pentax RAW File Structure JeffT Digital Processing, Software, and Printing 2 12-06-2009 11:10 PM
All times are GMT -7. The time now is 04:16 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
