Originally posted by Smoke665 That's what I did with the previous non P-TTL compatible speedlight. Usually setting the exposure by 1-2 stops under then using the speedlight to raise the exposure. However, I had hoped the this flash being compatible would eliminate this step
When you add a flash into the mix in the auto modes the camera can choose shutter speed/aperture/AUTO-ISO/and flash to give an overall exposure. The trouble is that the camera in any of the auto modes will have a good attempt at getting the exposure "correct" and generally will,
for the whole scene. But it has no idea what your artistic intention is. You may want a dark background but the camera will say "oh no we need more exposure to light those bushes behind". So it will choose a slower shutter speed/wider aperture/higher ISO to achieve that, especially if those damned bushes are beyond the range of the flash.
Yes you can dial in compensation for the ambient-light part of the exposure, but you are simply handing control of the choices to the camera, which may or may not work to give you what you want from the scene.
Where you have ambient light plus fill flash, you have two separate exposures going on at the same time. ISO and aperture will affect both exposures. Shutter speed will affect ambient alone (ignore HSS for the moment). The flash exposure will affect any part of the scene that is within it's range.
The reason why I and others posting on this thread advise to use Manual exposure camera mode is that it gives you the greatest control. You can be sure that the chosen aperture is right for your subject, and that the ISO is the lowest that will work effectively. You then allow the camera and flash to use it's P-TTL magic to give you an exposure for your subject and can dial in compensation on the flash unit to fine tune it. I am guessing you know a lot of this already having used a similar technique with a non- P-TTL flash.
