Originally posted by angerdan Given that I'm here I may as well comment.
The F 70-210 was a last attempt to improve IQ without the expense of aspherical elements. It purple fringes worse than any of the above mentioned, to the point where it is impossible to use with a TC, as the TC will magnify the purple fringing.
I've used it as a"take along in case needed when you don' expect to use it" type lens. In the session from which this was taken, a mink spotted in a pond while going shopping, in the end I wished I brought my DA*60-250. I got some images, but purple fringing ruined many of them.
I recommend it only to folks who can't afford better. It will cost you some images. Anyone with a DA 55-300 PLM seriously doesn't need it and shouldn't consider it.
When looking for quality lenses, I usually don't look at lenses rated less than 9, preferably 9.5 or over. Above 9, it can be really hard to see any difference between images taken with any of them with constant framing and DoF.
Quote: These are amazing pictures. Did not know that exiting TC is compatible with full frame. I was wrong
Not entirely, it's a decision that has to be made lens by lens.
