Originally posted by wanderer2 Thanks again for all of the replies and help. To clarify, here's what I want to do. I would like to keep the four birds in the image but to proceed to process that file with some routine adjustmemts - sharpness, haze reduciton, highlights / shadow adjustments, etc. I ordinarily do that in Affinity Photo but when I import the file into that program the image only has one bird, I assume because it's the first of the four exposures shot in PSR and AP can't process such a file, as has been described in the discussion above.
I have resurrected RawTherapee and immediately became lost in it, making me recall why I never progressed to using it. This is not the program's fault but mine, because of my limited understanding and skill using processing programs. So I would like to do whatever I need to do in RT to preserve the 4 birds when I move the file from RT to AP for further processing. If anyone can explain in detail the steps I need to do in RT to accomplish that I would be very appreciative. I would like to keep the involvement in RT as simple as possible, doing just enough to be able to export the file to AP and proceed from there with the four birds intact. I will have a lot of use for this in the future as I am currently shooting many mountain scenes using PSR and then HDR merges because of the high range from shadows to highlights, and as of now Affinity Photo simply uses the first exposure of PSR so I'm not gettng any benefit from PSR. At least, that's how I interpret the situation and some comparisons with PSR and non-PSR used in this way seem to bear this out. Thanks in advance for any suggestions and advice.
I wrote some lines of a possible process. Here are step's short story. For every frame create a 16 bit tiff within RawTherapee and transfer this image directly to Affinity Photo. There you copy all image layers together where you can apply masking to create your "4 bird" image. Melt them to one and apply all adjustments you like.
Here in more detail - good luck!
I only did a quick test without a four bird scenery PSR but using as "standard" PSR file on my Mac.
Pease try it and report if it works. Of course I'd like to see the result in this thread.
< Raw Therapee >
I. Preferences (=> get ready for export frames / subimages to Affinity Photo)
1. Go to General tab
2. Set external editor custom command line to ... open -a "Affinity Photo"
II. Browser
1. Show the browser area
2. Within the RawTherapee Browser PSR images show the tag "PS". By double click open the image within the Editor view
III. Demosaicing
1. Go to the Raw demosaicing tab (6th tab)
2. Select Demosaicing Method "Pixel Shift"
3. Select Subimage 1
4. Masking would eliminate the other "tree" birds I guess. So set Motion Correction Off.
What you like to do may also work with Motion Correction On or Auto. This way you may even get real PSR advantages cause the the important masking you do in Affinity Photo. Hope you know how to work with layers and masks in Affinity Photo?!
5. Press the "External Editor Button" to export the frame to Affinity Photo.
6. You now can see the frame as a tabbed window in Affinity Photo Editor. It should be of format 16 bit tiff with color profile RTv4_Large (similar to ProPhoto RGB).
7. Go back to RawTherapee and repeat step 4 to 5 for the other Subimgages No. 2 to 4 your PSR file.
You now you'll have four tabs with the four generated single frames of your PSR image within Affinity Photo. There you'll continue your work.
< Affinity Photo>
IV. Affinity Photo
1. Select one Image after the other an rename the layer to it's frame number (by example).
2. Copy each frame layer from it's file and paste it into the first affiniy photo working file.
3. For each frame you now should find one layer within the layer tool of the first image.
This is the base where you can use masking to get all four birds to be seen in the first image.
You can now make one out of the four layers, make adjustments as you like and export it.
V. RawPedia
RawPedia is the really nice Wiki style documentation of RawTherapee.
You should at least have a look at the following Topics:
1.
Color Management - Output Profile
2.
Preferences - External Editor
VI. YouTube Videos
By the way - your post triggered me to look at some RT videos on YouTube.
These two I highly recommend:
