02-09-2021, 11:56 PM   #1
Can we reset to a default exposure setting
Sometime I'd like to have my K1 start fresh with a standard exposure setting such as ISO100, 1/125th, f10. Instead of spinning dials to get to this setting as a default setting for the day.
I tried the green button. But pressing the green button trigger light metering and changes setting according to the light level seen through the lens, goes set exposure to a default exposure setting.
Is there a way to have the K1 camera remember a default exposure setting (e.g 100, 1/125, f10) and have it set there when switching it on or having the exposure settings reset to fixed values by pressing a button?
02-10-2021, 12:19 AM - 3 Likes   #2
Closed Account
Have you tried setting one of your USER modes biz ???
02-10-2021, 01:09 AM - 1 Like   #3
QuoteOriginally posted by pjv Quote
Exactly what I was going to suggest
I have a "birding" combination that trial and error has proven to be a very good compromise (TAv 1/1500 @ f/8 when using a long telephoto) and have this programmed into my cameras that have the option. Saves a lot of fiddling about in and out of menus and twiddling dials etc., both when an unexpected opportunity arises and I'm doing something else, or from a first start.
All settings can be changed, as normal, but, provided the settings aren't re-saved, the camera will always switch on to the pre-sets, so you can effectively use the on/off switch or the Mode dial as a "global reset"
Afterthought :- Do remember, the User Modes save virtually everything, including metering and a/f settings, so have all your options set as you like them when you save the mode.
02-10-2021, 04:06 AM - 1 Like   #4
Great idea. I've tried. It works. Thanks a lot
button, default, default exposure, dslr, exposure, f10, full frame, full-frame, k-1, k1, light, pentax k-1
K1 Mark II - RESET -- how to do it RIGHT - "Wrench(4)"- RESET is NOT complete vimlr007 Troubleshooting and Beginner Help 1 01-07-2021 11:39 AM
feature suggestion- reset to user default RobG Product Suggestions and Feedback 6 07-01-2019 07:04 AM
Reset K-7 Settings to default before selling? klkitchens Pentax DSLR Discussion 2 12-14-2012 08:55 AM
Eleven years ago we were attacked so we get to do whatever we want forever! boriscleto General Talk 8 10-02-2012 07:07 AM
All times are GMT -7. The time now is 06:30 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
