03-06-2021, 05:17 PM   #1
Illumination of buttons - not working for me
I was doing some night photography a day or so ago, and really could have used this feature. So I came home, dug out the manual, and changed the setting in the menu from 'off' to '2'. Menu shows that setting still, but pushing the illumination button (behind the ISO button) has no effect.
Is my camera body defective, or is there something that I don't know about using this feature?
Appreciate any feedback in this issue.
Thanks!
03-06-2021, 05:29 PM   #2
pschlute's Avatar
QuoteOriginally posted by GeeEmm Quote
Thanks!
My K1 has settings OFF/LOW/HIGH or OFF/ON..... cant see a "2" ?
Are you using USER modes by any chance ?
03-06-2021, 05:41 PM   #3
Did you pull out the lcd? Asking because when I first got my camera it wasn't obvious to me that those lights for the rear buttons are under it.
03-06-2021, 05:44 PM   #4
ehrwien's Avatar
The buttons themselves don't illuminate. What does light up, however, dependent on the settings you chose, are:
- the sd card slot
- the lens mount
- the top lcd display (perhaps the only one that really does light up itself)
- the leds behind the display on the back. You can use this to shed some light onto the buttons on the back when you pull it out from the body a bit
03-06-2021, 06:40 PM   #5
Thanks ehrwien and aaacb, pulled out the camera and bingo!! I was looking for them being back-lit. Duh.
pschlute, I have K1ii, my memory is that they were numeric values but I didn't check so I may have that wrong. But it works!
Thanks to you all!
03-14-2021, 02:41 PM   #6
angerdan's Avatar
Thanks to you all!
You can find additional informations in this thread:
External Lighting - how do you control/configure it? - PentaxForums.com
03-15-2021, 03:22 AM   #7
Thanks, I had found that menu, my problem was moving the screen for the lights to have effect. Only interested this time in the back, but I might turn on the lens mount one too next time I have the camera out..
button, dslr, feature, full frame, full-frame, illumination, illumination of buttons, k-1, k1, menu, pentax k-1
Night illumination... mahanpots Post Your Photos! 2 04-09-2020 08:07 PM
Pentax IstDs: left side buttons stopped working heki Troubleshooting and Beginner Help 6 10-08-2019 11:18 AM
Kr rear LCD screen and back buttons not working : a fix Christophe17 Troubleshooting and Beginner Help 2 01-17-2016 09:11 AM
KX buttons not working. PoisonedApple Visitors' Center 5 09-06-2011 10:30 PM
LCD Screen and buttons not working after a shot.. aliasant Pentax K-5 & K-5 II 7 02-07-2011 11:24 AM
All times are GMT -7. The time now is 10:49 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
