Originally posted by jumbleview How APC-S dedicated lenses work on K-1 in crop mode 1:1.
The good news is that given their APS-C image circle covers the long side of the image (~24mm) and a 1:1 FF crop does not require more than 24mm in neither the vertical (naturally) nor the horizontal (due to the crop) direction, a large proportion of the 1:1 crop will be fine. Indeed, edge performance will be as good as on APS-C.
The bad news is that the corners of such a 1:1 crop are further out (~34mm) than what the APS-C image circle has been designed for. So the corners of the 1:1 crop may be anything from unusable to completely fine, depending on the lens. It's the last 30% of the diagonals into the corners that one should check for when testing lenses; no need to check the edges outside the corners.
FWIW, vignetting is only one symptom one should look out for. Optical performance can become quite weak before vignetting becomes significant.
