Show Printable Version 12 Likes Search this Thread
04-06-2021, 12:05 PM   #1
K-1 II PEF Incompatible with macOS Catalina
I recently purchased a K-1 II camera and discovered Catalina does not support the .PEF format from my K-1 II camera when I want to see the photos in Finder or Preview.app. Thank goodness Adobe Bridge and my raw processing software can see them. QUESTION - Does anyone on the forum have Big Sur installed on their Mac? If yes, is the K-1 II .PEF format supported by Finder and Preview.app in the new macOS?
04-06-2021, 12:17 PM - 2 Likes   #2
Why not just put out .DNG's?
04-06-2021, 12:47 PM   #3
Not a Number's Avatar
QuoteOriginally posted by JohnMc Quote
That doesn't solve the problem with existing PEFs other than using the Adobe RAW converter.
This problem has cropped up quite often, unfortunately I don't recall the solution if any. There are several threads on issues of PEF files on various MacOS versions which should turn up using the search function.
04-06-2021, 01:07 PM   #4
May be talk to apple. PEF is around for a long time. Blame apple not pentax, why all of a sudden did they drop the driver for their built in viewers, processing engines?
04-06-2021, 01:11 PM - 1 Like   #5
jatrax's Avatar
This happens occasionally. I'm not an Apple guy so I have no explanation as to why.
However, the solution is to change to using the DNG format. For existing PEF files use the Adobe converter here to turn them into DNG.
04-06-2021, 01:17 PM   #6
QuoteOriginally posted by retpgmr Quote
Finder just browses your file system so I wonder if they would show up better in Finder if you had software installed on the mac that could open them. Do you have Digital Camera Utility 5 installed on the mac?
04-06-2021, 01:17 PM   #7
pschlute's Avatar
I have not used PEF for almost 15 years. I would also say I see no point viewing an unprocessed PEF or DNG file.
04-06-2021, 05:41 PM   #8
I have researched online and the majority of posts state that you lose some raw data if you shoot DNG instead of the camera's RAW format.
---------- Post added 04-06-21 at 05:43 PM ----------
QuoteOriginally posted by bwgv001 Quote
Yes PEF has been around for a long time. However, even PEF formats are different depending on the sensor you have in the Pentax camera.
---------- Post added 04-06-21 at 05:45 PM ----------
QuoteOriginally posted by NeoSpudly Quote
I will look for that software and give it a try. Thanks
04-06-2021, 06:16 PM - 3 Likes   #9
I think I would look at what folks here and on the various Pentax Facebook groups say they do. The overwhelming majority of us shoot DNG. Given that, as far as I know, the only cameras that natively shoot DNG are Pentax (and a couple of Samsung rebadges of Pentax bodies), I wouldn't trust what random people on the internet say about shooting DNG…they can't shoot DNG. They're repeating some old wives' tale about losing something when you convert your camera's native raw format to DNG. However, Adobe Evangelist Terry White (Nikon guy) always teaches conversion to DNG as part of his Lightroom courses. I trust Terry on these things.
04-06-2021, 06:59 PM   #10
ramseybuckeye's Avatar
I have BigSur 11.2.3, I just checked some old PEF files and they show up just fine when I did a "quick look".
DNG file do not lose anything, they are just "more compatible".
04-06-2021, 07:29 PM   #11
Paul the Sunman's Avatar
No problem on Big Sur.
04-06-2021, 07:57 PM   #12
@ RETPGMR "Yes PEF has been around for a long time. However, even PEF formats are different depending on the sensor you have in the Pentax camera"
I have never seen a reference to a change of PEF files, relative to sensor. Could you give me a link? I always was under the impression that they are 'Pentax-Standard' file containers.
I saw a few days ago another post about the potential problem with the new K3-III, writing files that no software can read, there they even discussed, the DNG, which in my opinion is a standard format. Would like to learn about the differences.
Thanks
04-06-2021, 08:43 PM - 2 Likes   #13
To quote the answer to my question from the Lightroom Queen's Forum:
Question: what is the difference between DNG and a camera manufacturer's proprietary format (in this case, PEF)?
Answer: DNG is a public universal format. The information fields in the DNG file header block are described and documented by Adobe (the developer of the file format) and made public for anyone to use. The data block for a RAW file contains values recorded at the Photosites on the sensor. RAW photo sites are not converted to RGB pixels. The PEF file format is like the DNG RAW file format in that it has a Header block and a RAW data block. So either file format contains the same photo site values in the data block. The difference between the two file formats is the information fields in the header block are not described and documented by Pentax and can only be read and interpreted by PENTAX image processing software. Eventually Adobe and other image processing software developers will reverse engineer the proprietary PEF file format and be able to process the PEF RAW file data.
So the actual picture data is no different, just the interpretation as instructed from the different Header block.
If you are a Lightroom/Photoshop user (and don't already know this), Lightroom Queen Forums is a fantastic resource.
04-07-2021, 12:02 AM   #14
StiffLegged's Avatar
QuoteOriginally posted by mtkeller Quote
...Given that, as far as I know, the only cameras that natively shoot DNG are Pentax (and a couple of Samsung rebadges of Pentax bodies), I wouldn't trust what random people on the internet say about shooting DNG...
DNG shooters include Leica mirrorless SL, SL2 and SL2S cameras, all digital Leicas in fact, so there you are: the best people shoot DNG.
04-07-2021, 12:27 AM   #15
No problem on Catalina 10.15.7 here. I just tried it on my older Mac.
Had to find a PEF first. Do not use it anymore. DNG is just more versatile.
apple, camera, catalina, dslr, finder, format, full frame, full-frame, ii, k-1, k-1 ii, k-1 ii pef, k1, mac, macos, pef, pentax, pentax k-1, software, time
Landscape Catalina Highway, climbing up Mount Lemmon North of Tucson, ARIZONA RICHARD L. Post Your Photos! 5 05-01-2021 02:17 AM
Machinery Felix the Catalina RobG Post Your Photos! 17 12-09-2020 03:41 PM
macOS integration. Howard2k Pentax K-70 & KF 3 07-05-2019 05:21 AM
Anyone figure out a fix so .PEF thumbnails (from K1) show up in MacOS finder? cam_abyss Troubleshooting and Beginner Help 4 09-16-2016 06:13 PM
K7 RAW Support in MacOS 10.6? potatolicious Pentax DSLR Discussion 9 09-04-2009 07:56 PM
All times are GMT -7. The time now is 01:37 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
