Originally posted by jumbleview From my memory of Pentax K200D : four Lithium AA Batteries lasted around 1000 shots while four regular AA lasted less then 200. Obviously numbers for K-1 would be different but relatively it should be the same.
My memory of the K200D is completely different. I have shot 1500 - 2000 pictures in a single day on my K200D + grip filled with eneloops. That was a long time ago. Daytime, no flash.
I use my K-1 II almost exclusively with 6 AAs in the grip, and no battery in the camera. The battery life is not nearly as good as with the K200D, though I have never measured it, and I haven't had any occasion to shoot that many pictures in a row again.
---------- Post added 05-03-21 at 12:39 AM ----------
Originally posted by i_trax I actually switched from Eneloops to LADDA ( IKEA ) , they perform much better , I think.
I have and use a large number of AA and AAA , I still have 1 set ( 4x AA ) Eneloops left.
But , while traveling I use The Energizer Ultimate Lithium only.
I know , it is not politically correct but they just last forever.
I have a lot of Eneloops (1800-2000 mAh versions), LADDA (2600 mAh versions) and Amazon Basic high capacity AAs. And when I say a lot, I mean a few hundreds.
Nearly all of my Amazon Basics high capacity AAs purchased in 2016 could no longer hold a charge, and had to be discarded. Some have claimed they are the same as Eneloops. I don't believe that's the case.
I have probably discarded 5% of 120 eneloops over a 13 period since I started using them.
For the Ikea LADDA, the jury is still out as far as I'm concerned. After a full charge and sitting for 6 months in my battery case, they definitely don't hold the charge as much as the Eneloops charged at the same time. They just wouldn't power the cameras, no matter which set I tried. Any randomly picked set of Eneloops would. I haven't compared the Ladda with Eneloop Pro, as I don't own any. Perhaps they are the same. But IMO, the LADDA are inferior to regular Eneloops when it comes to retaining charge in the long run.
And no, I don't use the batteries just for cameras. I have dozens of devices that need batteries, such as air fresheners, door locks, Roomba virtual walls, etc. For the Roomba VWs, I use adapters to convert 4 AA to 1 D cell, and 3 AAA to 1 C cell. That's why I need so many cells.
I also have a lot of battery chargers when the periodic recharging time is due, enough to recharge 100 batteries in a day. I only use chargers that have separate circuits for each cell, to fully charge each one.
