04-28-2021, 06:23 PM   #1
AA battery life
Hey folks,
Heading out this week on a trip - lost my charger at some point - I have two dead D-Li90's. Isn't that always the way things go before a trip. I'm out of practice since we haven't been able to go anywhere in so long I guess. No hope to get a new charger before we leave.
Luckily, I have the battery grip and AA tray - what's the battery life when powering the K-1 II with 6xAA batteries? Just wondering how many I should plan to buy on the way to the trip.
04-28-2021, 06:36 PM - 1 Like   #2
jumbleview's Avatar
From my memory of Pentax K200D : four Lithium AA Batteries lasted around 1000 shots while four regular AA lasted less then 200. Obviously numbers for K-1 would be different but relatively it should be the same.
04-28-2021, 06:42 PM   #3
Thanks! I wonder how AA rechargeables last - I have a pile of the black Eneloops I can use too. I'll plan on taking the Eneloops and if need be, pick up a pack of Lithium AA's at a Walmart or something at the destination.
04-28-2021, 07:24 PM   #4
QuoteOriginally posted by brofkand Quote
You can probably make a guesstimate based on the mAh rating of the Eneloops you have. A quick web search suggests these may be 2,000 mAh, whereas the D-DLI90 is rated at 1,860 mAh. Theoretically the life of the Eneloops should be similar, unless the voltage decays much faster.
04-28-2021, 07:32 PM   #5
There are generic camera battery chargers. One size fits all. I have an Inca universal charger bought in Sydney. Not sure what the equivalent might be in the US.
04-28-2021, 08:04 PM   #6
My experience with a K50 and 4 AA alkaline is about 100-150 shots. 4 AA lithium about 700-800 shots. Turning of the rear display, flash, gps, and anything else that uses power that you don't need will extend battery life. Even switching to manual focus will save a lot of power.
04-28-2021, 08:08 PM   #7
Hey folks,
I found with generic rechargeables it was no where near as good as dli90s
04-28-2021, 09:50 PM   #8
dms
QuoteOriginally posted by DWS1 Quote
Although I never actually took a count, this is also my gut feeling about AA lithium (Energizer) vs rechargeable eneloop AAs. An order of magnitude difference.
04-28-2021, 11:30 PM   #9
i_trax's Avatar
For traveling I always use The Energizer Ultimate Lithium , they just last forever.
They are not cheep but worth every cent , not really comparable with any other AA.
04-29-2021, 12:20 AM   #10
fs999's Avatar
Eneloops are better for the planet too... You can charge them more than 500 times...
04-29-2021, 02:12 AM   #11
i_trax's Avatar
I actually switched from Eneloops to LADDA ( IKEA ) , they perform much better , I think.
I have and use a large number of AA and AAA , I still have 1 set ( 4x AA ) Eneloops left.
But , while traveling I use The Energizer Ultimate Lithium only.
I know , it is not politically correct but they just last forever.
04-29-2021, 04:42 AM   #12
wstruth's Avatar
Hey folks,
Not sure about how many shots you get but lithium's will power more shots followed closely by Eneloops (from my flash use i would say 75% to 70% of lithiums), and then much further down good AA's Maybe 1/2 to a 1/3 of lithiums.
04-29-2021, 05:26 AM   #13
QuoteOriginally posted by wstruth Quote
The Energizer Ultimate Lithium AA batteries are rated at 3,000 mAh. Assuming the Eneloops are rated at 2,000 mAh (66% of the capacity), your 70-75% estimate for the number of flash shots seems reasonable.
04-29-2021, 07:41 AM   #14
I have been using LADDA for a long time and they are really amazing, I highly recommend them.
04-29-2021, 09:54 AM   #15
The Eneloop Pro grey ones are rated 2600mAh. I find they outlast all other rechargeables I have, except Lithium. I used them in flashes extensively.
batteries, battery, cell, charger, dslr, eneloops, full frame, full-frame, k-1, k-1 ii, k1, k200d, life, lot, pentax k-1, time, trip
battery grip AA battery life enyaw Troubleshooting and Beginner Help 7 08-23-2019 07:19 PM
Longest battery life models - Preferably AA battery and waterproof. cadmus Pentax Compact Cameras 8 07-04-2016 08:33 PM
battery life with BH109 AA holder bcorson Pentax K-30 & K-50 40 05-07-2013 05:31 PM
AA battery life jslifoaw Pentax DSLR Discussion 54 06-05-2011 05:26 PM
AA battery life with video m_austin_j Video and Pentax HDSLRs 3 11-24-2009 07:38 AM
All times are GMT -7. The time now is 01:54 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
