Show Printable Version 9 Likes Search this Thread
06-01-2021, 11:37 PM - 1 Like   #16
Live View CDAF is not always as accurate as I would hope, sometimes significantly worse than PDAF or manual focus (using magnification.) Assuming the camera is set to spot focus with the spot on a well lighted subject of reasonable contrast, are there any menu items that can affect CDAF accuracy?
06-02-2021, 12:51 AM   #17
Clavius's Avatar
Ok, this morning I did some more testing... Some suggested to use the select focus instead of spot focus and I wanted to quickly try that. At first I thought that that resolved the issues. Which is great of course! But when I returned to spot focus again I could no longer reproduce the error?! I cannot just let that go and forget about it without knowing what caused it.
Only after some more extensive testing, trying to reproduce the error, it came back. In both spot AF and select AF. I also noticed that the colors in photos taken with LV seem desaturated in comparison to photos taken through the OVF. It can also be seen in the test photos that I posted earlier in this thread.
This maybe a stupid theory of mine, but could it be caused by the sensor heating up? Or because it's used longer in live view mode? In live view the sensor is used to feed information to the screen constantly. But when using the OVF it is "resting" until the actual picture is taken.
I find this so strange, because in my K-5 I am so used to AF in live view being much more precise. There it would seem the other way round.
06-02-2021, 03:42 AM   #18
Overheating sensor would, I think, results in more noise. Your problem is very odd.
06-02-2021, 04:14 AM   #19
dlhawes
Guest
My guess is that the camera's internals are slightly maladjusted such that the distance from the lens to the sensor isn't the same as the distance from the lens to the focusing sensor. You may have compensated for that using the AF microadjustment function for viewfinder focus, so that's coming out right, but that compensation doesn't apply to live-view focus.
06-02-2021, 04:22 AM   #20
Clavius's Avatar
QuoteOriginally posted by Medex Quote
Did you try central spot focus only in Live View? How about "Select" focus mode and using another area to auto focus? Same missed focus?
QuoteOriginally posted by dlhawes Quote
No, I have no microadjustments active. Menu for microadjustments is set to 1 / defaults.
06-02-2021, 08:56 AM - 1 Like   #21
Unregistered User
Guest
I have found that Tamron 70-200 are unable to nail focus in Live View on K-5. Why? I never understood. Always back or front focus. But OVF no problem.
Then there is the problem that when you focus the lens it is fully open and if stopped down when shooting there may be a shift in focus, called focus shift. I have had that on a couple of lenses. The OVF focus knows this and compensates while LV focus seeks maximum contrast.
---------- Post added 06-02-21 at 05:58 PM ----------
QuoteOriginally posted by Clavius Quote
Are you shooting in strong light and using LV you may get light leaks through the viewfinder. Make sure to always cover the OVF.
06-03-2021, 04:49 AM   #22
QuoteOriginally posted by Tjompen1968 Quote
I'm not sure. OVF focus is wide open, but live view is done at F4, perhaps even lower if there is a lot of light. That said field of view is wider when stopped down. At which apertures the actual pictures are taken?
06-03-2021, 07:33 AM - 2 Likes   #23
Clavius's Avatar
Covering the OVF resolves all issues! I hadn't thought of that, because that wasn't necessary with my K-5. The viewfinder of the K-1 is much larger and brighter of course, and lets in much more light through the other direction too.
I'm so happy that my camera isn't broken. Embarrassed, but happy.
06-03-2021, 08:52 AM - 2 Likes   #24
Covering the viewfinder is key for exposure too, at times. Just get in the habit of doing it. Wearing black/dark colours can also be useful as I found out when I had some odd results after wearing a white t-shirt on a sunny day. I just cover the viewfinder automatically when I'm MUP/remote etc. on sunny days.
06-03-2021, 09:00 AM - 1 Like   #25
dlhawes
Guest
That being the case, I strongly suspect the camera is "broken". My suggestion that the camera itself is not properly adjusted was based on my own experience and learning curve with respect to a K-1 I eventually had to send back to be repaired.
06-05-2021, 11:43 AM   #26
No need to be embarrassed- I have learned through your experience! Perhaps others have as well. I do usually cover the VF when shooting on tripod, but not always if in a well-shaded spot. However, that has always been to address proper exposure. I would never have guessed AF would be affected! I shall now always do so when using LV!!
06-05-2021, 01:00 PM   #27
Mikesul's Avatar
Pentax includes a viewfinder cover in the box just for this kind of problem.
06-05-2021, 05:03 PM   #28
And, LV is not always done on a tripod, so the covering of the OVF is always important both for AF and for exposure!
06-05-2021, 08:45 PM   #29
Cover
I think one of my MZ-S camera straps has one on it and a remote shutter release on the other side.
06-06-2021, 04:44 AM   #30
pschlute's Avatar
QuoteOriginally posted by BarryE Quote
Although for different reasons (flash meter), the portrait photographer's standard garb is black t shirt.
---------- Post added 06-06-21 at 12:46 PM ----------
But in LV focussing is done "on the sensor".....there can be no misalignment.
af, distance, dslr, focus, full frame, full-frame, iso, k-1, k-1 ii, k-1mkii missing focus, k1, lens, light, liveview, pentax k-1, photos, self, sensor, timer, view
Lav mic and shotgun mic for the K-1Mkii DougTank Pentax K-1 & K-1 II 7 01-01-2020 08:49 AM
Landscape Creating Super Resolution Images Handheld (like a K-1mkii, but not). BruceBanner Photographic Technique 84 10-13-2018 07:25 PM
K-1mkII overpowered NR. Firmware update? i83N Pentax K-1 & K-1 II 87 05-23-2018 12:40 AM
SLR Lounge- Noise comparison shot K-1 vs K-1mkII @ISO 12800 - good improvement interested_observer Pentax News and Rumors 51 03-06-2018 11:42 AM
All times are GMT -7. The time now is 09:54 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
