06-13-2021, 12:09 PM   #16
Tjompen1968's Avatar
QuoteOriginally posted by Boydmaine Quote
Isn’t Shake Reduction supposed to be turned off if you use a tripod? Was it?
Yes it was off.
---------- Post added 06-13-21 at 09:11 PM ----------
QuoteOriginally posted by Sakura Quote
But why would you use automatic horizon correction on a tripod while you have all the time of the world to adjust you're ball head so the camera itself is horizontal ????
I think this function is totally useless when using a tripod. (or am i missing something?)
Well, this is a function that you turn on and leave on. It works perfectly on the K-1 today but in the past there was some issues and I am trying to figure out if it is the same problem the K-1 had that the K-3 III has.
And I do not find it to be useless on a tripod. Why do you think that? If I miss level with one degree it will be visible in the final image but if HC is on it will be level and I do not have to crop the image. Saving pixels.
06-13-2021, 01:17 PM   #17
Otis Memorial Pentaxian
He remembers the K-1 having had a similar issue that was eventually fixed with a firmware update.
I vaguely remember that thread, though I don't remember the specifics of the resolution. In regards to this thread, I have been wondering if turning of the SR in combination with the horizon correction is the indirect cause (i.e. the timer is a red herring).
06-13-2021, 01:36 PM - 1 Like   #18
As the OP said, it's the sort of thing that you turn on and leave on. It shouldn't have this downside that appears when you use the two second timer. It's a bug. At a minimum Pentax should disable this feature if they can't make the two work together, but it is awfully handy if you have your camera really close to level to know the sensor will fix the last little bit for you.
06-13-2021, 03:04 PM - 1 Like   #19
JimJohnson's Avatar
Location: Summer:Lake Superior - Michigan Winter:Texas Hill Country
I don't know if OP has the K-1 or K-1ii. I have the K-1:
So far as I know, none of the Pentax cameras auto-detect use of a tripod, but in all cases it is recommended that Shake Reduction be manually turned off when using a tripod. You have a couple options for configuring your K-1 to toggle this from buttons on the left side of the mirror box.
Further:
K-1 manual, page 56
The [Shake Reduction] of the <camera>4 menu is automatically set to [OFF] when the drive mode is set to [Self-timer], [Remote Control], or [Mirror Lock-up Shooting]. If you do not want to turn off the Shake Reduction function, set in [21 Auto SR Off] of the C3 menu.
The K-1 manual also says that Horizon Correction is limited to 2 degrees with SR off and 1 degree with SR on.
06-13-2021, 03:45 PM   #20
To be clear i repeat my question:
In 2016 I shot some images with the K-1 on tripod and with 12 s timer. SR automatically turned off. Horizon correction on.
I could not get a sharp image. Found help on the forum and turned on or off something but can´t remember what it was.
Anyone that remembers?
The problem was fixed in Firmware so it is not an issue anymore but I want to know how it was avoided back before FW was fixed.
06-13-2021, 04:06 PM   #21
QuoteOriginally posted by Tjompen1968 Quote
If this was the post you refer to there is no clue what you did.
https://www.pentaxforums.com/forums/190-pentax-k-1-k-1-ii/334297-oof-images-scratching-my-head-post3833573.html
06-13-2021, 04:33 PM   #22
SelrahCharleS's Avatar
At least on the ball head I have it's a big time saver so that I don't have to spend all my time adjusting it to get it perfectly level (it might be less of an issue if I had a nicer ball head). I pretty much turn the feature on and never think about it again.
06-14-2021, 01:45 AM   #23
QuoteOriginally posted by slartibartfast01 Quote
OOF images.. Scratching my head. - PentaxForums.com
Thanks!
Yes it was the thread and yes the problem seems to have been the horizon correction.
06-14-2021, 09:14 AM   #24
QuoteOriginally posted by SelrahCharleS Quote
Just use a water level, always leveled pictures
06-14-2021, 09:18 AM   #25
Thanks!
Don't forget this part...
When in Live view there was no problem, only when using OVF
06-14-2021, 09:29 AM   #26
If it is built in and doing the job automatically there is no need for a water level.
06-14-2021, 12:07 PM - 1 Like   #27
Different strokes for different folk!
I do a lot of off-angle work and the last thing I need is for the camera to be second-guessing the composition, even with landscapes. I don't know for sure, but am fairly certain that none of the elements in the subject for the photo below were level or plumb, but I did know my composition before I set the tripod down.
Everything at Ebey's Landing is tilted.
dslr, exposure, focus, full frame, full-frame, function, horizon correction, image, k-1, k-1 ii, k1, liveview, mirror, motion, pentax k-1, shutter, switch, thread, timer, tripod, unsharp image, vf
Abstract Totally unsharp yet so beautiful RICHARD L. Post Your Photos! 2 10-01-2020 12:44 PM
Unsharp mask - Transit of Venus steephill Monthly Photo Contests 7 07-13-2020 09:15 PM
Unsharp mask...what is it for? slackercruster Film Processing, Scanning, and Darkroom 3 02-20-2012 04:06 AM
K20D, unsharp photos! BakDinitzen Troubleshooting and Beginner Help 27 04-30-2011 06:06 AM
k-x unsharp focus nikko Pentax DSLR Discussion 5 04-26-2011 11:18 AM
All times are GMT -7. The time now is 03:31 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
