Dmach47, sorry to say you're mistaken on both counts.
You might enjoy reading this article on the CMOS sensors supplied by Teledyne e2v for the Eurmetsat::
Teledyne e2v delivers first flight module for EUMETSAT?s Meteosat Third Generation (MTG) | Teledyne Imaging
and here's an interesting article touching on some of the differences between CMOS Active Pixel Sensors and Charge Coupled Devices, in the context of scientific imaging (astronomy):
CCD versus CMOS: Which is Better? - Astronomy & Scientific Imaging Solutions
Both CCD and CMOS APS have photo-sensitive pixels; the main difference is how to convert the charge or voltage to a digital number, and how fast you can do it.
CCD's usually have the charge clocked across the row and out a corner of the chip through an amplifier, and then an analog to digital converter (ADC) chip on the circuit board converts it to a number. There are usually 1-4 readout channels and ADCs, allowing up to 4 quadrants of the chip to be read out at a time.
CMOS APS devices have the voltage passed to a column ampliifier to an on-chip ADC; there are many many parallel ADCs allowing simultaneous readouts; this makes the APS device much faster to read out the entire array, as compared to a CCD.
Both devices may have a micro-lens array which concentrates light in about a 30 degree cone onto the pixel. On APS devices, this can be really critical, as the pixel is small and surrounded by 4-5 transistors, and the pixel doesn't completely fill the square with it's neighbour. (Fill Factor).
If it's a Bayer colour sensor or a Sparse Colour, there is a micro-filter array of RGGB or LRGB fitlers above the pixels, sometimes incorporated with the microlenses.
Both devices can be front-illuminated (FSI), meaning that the light may have to pass through some semi-transparent electrodes that make up the circuitry, or back-side iluminated (BSI), where the rear of the chip gets polished down thin enough to allow light to hit the pixels without going through the logic. BSI costs more to make, as it's harder to get good yields.
Sensitivity is a function of the wavelengths of light that the semiconductor responds to; there is an Absolute Quantum Efficiency curve used to figure out how sensitive the chip is to light of different colour, eg 400nm to just under 1000nm for Sony chips.
The Teledyne e2v parts are even more sensitive (and very expensive). If there are colour filters and microlenses, that impacts it. Then the chip may have an amplifier gain control - the readout amplifier (CCD) or AP transistors and column amps (CMOS APS) may boost the signal level a bit. The Sony and Gpixel CMOS APS devices have a dual-gain mode for High-Dynamic Range (HDR) operation.
So there's a lot that goes into it. (I haven't mentioned calibration!)
