Originally posted by tduell OK.
Does that give you 16 bit tiff and also give you the raw file?
Cheers,
Terry
I'm not sure if it is a 16 bit tiff, but you definitely can keep both the raw file and the developed tiff file.
To the OP: I think others have answered your question, but the idea with pixel shift is to give you better quality pixels, not more of them. So this is no super-resolution technique, as Olympus has. My experience says that when there is minimal movement in a scene, pixel shift gives more color depth and decreases shadow noise, such that I can push images harder without them looking pushed.
I mainly use Raw Therapee for development to a 16 bit TIFF file and then edit that in Lightroom. Lightroom is able to edit pixel shift images, but it produces artifacts everywhere where there is movement, whereas RT has a very powerful motion correction algorithm that masks in a single image's detail on areas with motion (you choose which of the 4 images the program uses). Anyway, that's what I do and it is pretty simple and fast and I use pixel shift a lot for landscape photography.
