Originally posted by jdou I did not press the green button but set the camera to manual and B button from the top knob
Please explain what you mean by this. As written it is not possible to set the camera to both manual and B. For Bulb your C1 menu has to be set to either #1 press the shutter to start and release to end or #2 press to start and press again to end. If not auto timed via the camera then in either case you would have to have some type of timer to know when to manually release via either of these two.
There is a note in the manual if I recall about not having the camera set to af-c focus.
PS Don't forget another possibility is some sofware don't read the exif completely accurate.
