Originally posted by UncleVanya I mentioned the buffer because the buffer, more than the write speed is what limits continuous shooting the most.
I didn't think that through thoroughly enough, but you're so right. Thanks for pointing out the difference. Ofcourse shooting 36mp or 24mp still is quite a difference in filesize to buffer, but the K-1 is equiped for that.
Originally posted by UncleVanya If the goal is to use legacy wide angle glass at the original angle of view, what other choices do you have?
My other option would be a used
SMC Pentax-DA 14mm F2.8 ED [IF] lens to fit on my KP, to fill the need for a wider angle image. That would be the only DA lens in my collection of A 24, 28, 50, 35-105 and M 200 and 300 lenses. Not out of principle, but a brighter use of the set - a K-1 could be a nice addition to step up another level in image quality.
