Originally posted by JimJohnson Interesting thread. For me, I think Norm stated it best. I shoot in the field and can make multiple representations of the subject via cropping in post-processing.
I also crop digital on display as the appropriate crop can strengthen a composition, there is no restriction of aspect ratio in digital, it can be anything really, so it doesn't really matter how the composition fits in the frame. Printing is different, print sizes and frames are mostly standardized, it's 3:2, 4:3, 5:4, 16:9 and 1:1, and yes it's possible to play with white borders and the width of mat boards, but unbalanced picture to frame borders aren't necessarily wanted. I understand norm's perspective as he almost never print, display his picture on monitor or 4K TV.
---------- Post added 04-12-21 at 08:44 ----------
Originally posted by Wheatridger I generally prefer these shapes, because they look like the 8x10 prints I used to make in the darkroom.
Same here. A bit part of the large format look is its aspect ratio. I find that 3:2 isn't quite as wide for horizontal landscape shots (I prefer 16:9 in that case), and 3:2 is too long for vertical portrait shots (I prefer 4:3 or 5:4 in those cases). Only 20% of my prints have 3:2 ratio, most other are 4:3, 5:4, and 16:9 or 2:1 for panoramic views. I prefer ratio closer to square for prints because standard frames size are usually half way between 3:2 and 4:3 or 5:4. No only standard frame sizes aren't 3:2, but also backing boards aren't 3:2. Backing boards and mat window sheets standard sizes here are 100 x 70 cm (<3:2, > 4:3) or 100 x 80 cm (5:4), and multiple of these sizes ( 50 x 70 cm, 140 x 100 cm etc.).
---------- Post added 04-12-21 at 08:58 ----------
Canon 5DSr features five crop modes and aspect ratios: 3:2, 3:2 x1.3 crop, 3:2 x1.6 crop, 4:3 and 16:9. And there are two options to show the crops: Outlined or Masked (edges are blacked out). I think that's pretty useful. If you shot vertical you can use the 4:3 setting, if you shoot horizontal you can set the 16:9 setting, outlined or masked according to preferences.
