After taking 4000 exposures for a time-lapse, using in interval mode of the K1, I was rather astonished that the battery indicator was still at 3 bars (full battery).
However, if I set the standby timer to "off", and leave the camera switched on without taking any picture, a full battery is completely discharged in 6 hours (DSLR) or 3 hours in live view mode.
If taking pictures is not what discharges the battery the most, I was questioning what would be the ideal power-down timer setting to get the most out of a fully charged battery.
I remember having used the 1 minute power down setting, having the camera wake up every time I want to take a picture but the battery didn't last as long as I expected.
I searched for CIPA ratings online and I found a document from 2003 that defines how camera battery life should be measured:
http://w5.twgp.com/pdf/DC-X002_E.pdf
Below some excerpts I selected from the document.
2. Measurement 2.1 Prerequisites
a)The basic rule for conducting the measurements is that all of the still-photography functions
of the digital camera shall be utilized to their full extent. Non-still photography functions (e.g.
audio- and movie-recording functions) need not be activated during the measurements. b)The camera’s function-setting parameters, except those de fined in this measurement
procedure, shall be basically identical to the de fault settings at the factory.
2.5 Flash photography Full illumination flash shall be used for one of every two pictures taken.
For the other pictures, the flash shall not be used.
2.9 Motor driven optical zoom operation Before every picture is taken, the motor driven
optical zoom lens shall be moved either fro m the TELE end to the WIDE end, or from the
WIDE end to the TELE end. It is also acc eptable to move the zoom lens either as
TELE→WIDE→TELE, or as WIDE →TELE→WIDE before every second picture is taken. 2.10 AE/AF operation The AE/AF operation shall be done in accordance with the default
factory setting. No procedure is set forth herein for the operation. 2.11 Operating environment Measurements shall be made at 23°C ± 2°C, Relative Humidity
(RH) 50% ± 20%.
2.18 Handling of playback mode Nothing is specified regarding the playback mode and
automatic playback (the function for displaying images automatically immediately after they are
shot).
2.19 Shooting intervals Shooting shall begin 30 seconds after the power is turned on. During
that 30-second interval, the flash mode setting, zoom operation and other preparations for
shooting shall be made. Thereafter, shooting shall proceed at a rate of one picture every 30
seconds. If 30 seconds is not sufficient for initialization, or if the camera is not ready for
shooting 30 seconds after a shot, shooting shall resume immediately after the camera reaches its
ready state.
2.20 Power off frequency and intervals (see Explanatory Notes) Power shall be turned off
after every 10th picture has been shot and processed. The interval before the next power-on
shall be as much time as needed, without affecting battery life (i.e. so that any additional off
time will not change the measurement results). It shall be the responsibility of each
manufacturer to determine the appropriate length of off time.
