I try to avoid this culture of exclusivity - this! and only this! ... and since decennies I avoided, so to say, the normal lens. This is a big world with many aspects, waiting for being uncovered. Ever more and again and again, in move. Say, it needs two, at least. Looked at the one, now, how does the other look like. Or so.
Far away in time I had Nikkors, a 35/f3.5 and a 85/f2. Later with Contax a Distagon 28/2.0 (yes that one, but I didn't care) and a Planar 135/2.0. In times of data crazyness now thiose sit on an Oly-Pen. Before times of pixel peeking it was easier to get excited about fine quality, not because of a good name and talk about endless perfection, but beause of obvious results to be seen. Growing into postprocesssing now, (as I was used to darkroom practise before), I found the Foveons appalling - liost a DP1 (which is 28mm equivalent), and after a DP2 there was a pair again, the DP1M (28mm) and DP3M (75mm). Continuity preserved.
Questions arose - not around the like: will that thing deliver the best and the ultimative - ... but just the opposite: is there missing something? So for quite some time, noe with the K1, I found the Tokina 28-70 sometimes to deliver, but sometimes not. Found the old M35-70 in comparison then, which would deliver quite more often.
Made some comparisons from published pics the other day, with the DFA 24-70, against the DFA 28-105, but even if the latter has its audience, I would not go there if I had the choice (I loolked around beause of WR). Very second hand so to say, just from viewing, I found more fine approaches with the 24-70 in such terms, jist to deliver. But ok .. I am spoled now anyway, with fine pairs again, as the FA31 and the old K135f2.5 (and for more such kind of exercise, FA*24 against FA*85). Found hardly a situation where those would not deliver (except the FA*24 which requires some special attention).
This is rather not a technical question ... for this one, the DFA 50 Macro would give me an answer, this is precision like crazy, as I'll hardly ever need it. It's for me more a question of taste and approach, when asking if thiat thing delivers. But when having found a lot of nice situations for the FA31,. suddenly the astonishing M35-70 sits around and delivers better, for some situations encountered.
Btw for about WR when having used for quite some years those Foveons, I found, no, those are not declared as water resistant but quality of build would help tolerate quite some bad weather. when taking general care a bit. But other way round, with that Contax in some former time use, I learnt afterwards, that quality of build has not been sufficient in this regards, moisture had crept in and made some problems much later. In times of delicate mechanics this might have been more critical anyway. Those Foveons would have resisted similar conditions better.
But I would not expose stuff to some real rain with non-WR stuff anyway. So I looked if the DFA 28-105 would be an alternative - and I found, against those FA31, K135 and even the M35-70, there was not real need for a DFA 24-70 to come in, except for built-in resilience, but maybe I do not want to know for real.
Just a personal view. Maybe there is very wet seasons ahead, who knows, so to reconsider.
