Originally posted by yucatanPentax
Do you find that Pentax cameras any headroom to expose to the right?
My anecdotal (i.e, not bench tested but just my experience in the field) is that my Pentax cameras cannot be ETTR'd to the same degree as the Canon cameras I sometimes use at work. Canon's seem very forgiving in this way. OTOH, my Pentax cameras behave much better underexposed than the Canon's by a wide margin imo. I routinely underexpose my Pentax captures because I have found that the penalty for getting it wrong with ETTR with my cameras can be severe, but there's almost never a penalty for underexposing somewhat. I don't understand whether this is a metering thing with Pentax, or as Digitalis says above a difference in the sensor---I'm generally inclined to listen to what he says, though, as his expertise is extensive.
I used to ETTR based on the late Michael Reichman's advice, but I personally began to find it not applicable in all cases even before I got (back) into Pentax. Also, the fact that the histograms in cameras are based of jpg gives me pause. Fortunately my Pentax cameras behave in a way that seems natural to me, so I no longer worry about it too much except when there are no highlights to blow. Then I do push to the right.
