Originally posted by retpgmr I recently watched a couple of YouTube videos where it was suggested I should turn OFF the D-Range Settings (Shadow & Highlight Correction) on my camera. Any opinions one way or the other? I currently have my settings on AUTO. Thanks for any input.
What is the purpose of these two settings?
Automatic adjustment (correction) to parts of an image. Like "fire & forget", no matter what scene.
To
which parts?
- The Shadow Correction is applied to very dark parts, if they exist. If the image doesn't have those shadow areas, then no correction happens.
- The Highlight Correction is applied to very bright parts, if they exist. If the image doesn't have those highlight areas, then no correction happens.
Why apply corrections?
Without the
Shadow Correction setting, the image
would appear very underexposed, without details in the shadows. Not the entire image bad, just the dark part too dark. The rest of the image would look fine on the display, on a screen or on paper.
Without the
Highlight Correction setting, the image
would appear very overexposed, without details in the bright parts, such as in the sky. Details about the bright clouds would appear "blown out", too white, on the display, on a screen or on paper. The other parts of the final image would still look good.
Why does that happen? We humans see
more detail with our eyes than the camera
is able to capture in a single exposure. The "dynamic range" of our eyes (+brains) is larger than what the camera can see. What is too bright for the camera is put as pure white in the image and what is too dark for the camera is put as pure black in the image. But we want to see those details (in both shadows and highlights)
in the final image, on any screen or printed on paper.
The trick how to get details back is done through
tone mapping. It is a compromise, a middle way, a compression of tones. In reality we see way too many shades and hues and we put only some of them on paper (or on screen) in a clever way that looks realistic enough - through tone mapping.
As I said, it's an automatic adjustment to retain more image information, done even if it doesn't fit an
artistic intent. Sometimes there is too much correction. In such cases, turn the setting off.
Beware, you need ISO 200 or higher, for the trick to function. It doesn't work at ISO 100.
Jpeg shooters: don't click on that:
