I really tried all sort of angle, strongly shaking it in every way, mirror lock up also, it didn't change anything, didn't feel anything moving inside, it's like this little element got stuck pretty badly. It seems hopeless.
Originally posted by thepedant I was wondering if, because the problem is not being able to remove the lens, that it's the lens removal mechanism that is broken and that the lever that appeared in your picture is part of that mechanism. I took the lens off my K1mk2 and tried to see what happens when I press the lens release button but I couldn't see anything moving except the focusing pin.
I just tried estimating the distance with my 31mm to compare, it's hard to tell. Here's a picture of my lens where the initial point is aligned with the made in Vietnam at the center, and at its maximum point counter-clockwise, from there, I cannot rotate it any further, and It doesn't come out. And now I'm seeing that more, it might be not as far as usual, it might be not enough to come out finally.
