08-27-2022, 06:06 AM - 1 Like   #1
Lenses for Astrotracer
I bought my Pentax K-1 II primarily to shot stars in the sky and deep space objects.
So far have the Pentax-D FA 15-30mm 2.8 that should be good to use with the Astrotracer.
Next, I have the Pentax-M 50mm 1.4, from my Pentax MX, that I think to upgrade to the Pentax-D FA* 50mm 1.4. This lens apparently has some comatic aberrations, but should be good for panoramas. The 85mm is slightly better, but more expensive and complicated to get used.
My next lens is the Pentax-D FA 100mm 2.8 WR Macro, but this lens has much bokeh fringing, and is not apparently a good option for astrophotography.
From there on, I thought about the highly regarded Rokinon 135mm 2.0 ED. Too bad there is no way to use my Zeiss APO Sonnar 2/135 ZF.2 or Voigtlander Macro APO Lanthar 125mm 2.5 SL, the last one will God willing arrive in few days, but unfortunately both are for Nikon. That being said, the Rokinon also seems to be an APO lens and is much less expensive. Initially the idea was to get the Pentax D FA 150-450mm 4.5-5.6 but this lens is very expensive and it’s f stops are a bit slow.
What other lens is recommended over 135mm 2.0 for astrophotography? Is something like the Pentax-A* 300mm f/4 suitable?
08-27-2022, 07:29 AM - 1 Like   #2
Arne Martin's Avatar
Hi Igor and welcome to the forum !
I was lucky to find a used D FA 150-450mm on ebay for a very nice prize. The only lense I have tested for astro objects and it is awesome !
Here is my test image:Andromeda from Tenerife - PentaxForums.com
Another solution could be getting a smaller telescope and use an adaptor to mount your K-1 II ? Some of them are cheaper than the 150-450 mm for sure.
08-27-2022, 09:19 PM   #3
QuoteOriginally posted by Arne Martin Quote
Perhaps it will be better to stick with the original plan and get the Pentax D FA 150-450mm 4.5-5.6.
Btw, what focal length did you use for your photos?
---------- Post added 08-27-22 at 09:23 PM ----------
QuoteOriginally posted by Michaelina2 Quote
Check out...
https://youtu.be/qigGXEcf7hE
Their YouTube channel contains tons of useful info.
Cheers... M
BTW: They have lots of good things to say about Pentax HD DFA 28-105.
Interesting, I was also surprised when I took a good look at the K-1 and the K-1 II. It’s better in many aspects compared to my other high resolution cameras (A7R II, D800 and 5DS).
09-09-2022, 03:07 AM   #4
QuoteOriginally posted by Igor Sotelo Quote
Sorry for late answer, but I was driving around Denmark and Germany on my motorsycle.
I used the full lenght 450 for the session.
apo, btw, dslr, fa, fa 150-450mm, full frame, full-frame, ii, k-1, k-1 ii, k1, lens, macro, pentax, pentax k-1, rokinon
Astrophotography with lenses > 100mm and Astrotracer vinikrish Pentax K-1 & K-1 II 13 12-14-2021 06:38 PM
Astrotracer with D-70 and Manual Lens JimCase Troubleshooting and Beginner Help 7 01-19-2021 10:57 PM
Astrotracer in K-1 and telephoto lenses banep Pentax K-1 & K-1 II 4 05-21-2016 03:08 PM
The K-3II astrotracer(or o-gps1), and wide angle lenses.. an observation. Auzzie-Phoenix Photographic Technique 12 04-13-2016 05:06 PM
Does the O-GPS1 Astrotracer work with manual mirror lenses? maxxxx Pentax Camera and Field Accessories 8 01-25-2014 09:42 AM
All times are GMT -7. The time now is 09:29 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
