11-13-2022, 09:50 AM   #16
I had the focus on infinity. I don't have my photos on any sites such as Flickr, so I can't post a link.
11-13-2022, 05:43 PM   #17
pschlute's Avatar
QuoteOriginally posted by Photogoof Quote
Most modern lenses can be focussed beyond infinity. The reason they are made this way is to allow for expansion due to heat.
if you turn the focus ring to the maximum you are focussing beyond infinity and will get a poor image.
11-16-2022, 11:13 AM   #18
They also went past infinity to properly focus past infinity. I have an old lens or two that actually marks the IR infinity point.
11-20-2022, 01:32 PM   #19
To test for infinity focus, it is not best to do so with your frame filled with subject matter located a lot closer than the horizon. Manually focusing to infinity for a scene like this would more likely put most of it out of focus. To test for accurate focus other than infinity, it is best to set AF to center-only spot AF and find one particular object having clear-cut edges and well defined detail to focus on. A tree with a bunch of leaves allows the focus point to be hard to recognize, being trained about anywhere within the scope of the shot!
One of your old prime (non-zoom) lenses might have a distance scale by the aperture ring which will allow you to maximize your depth of field (DOF) for a particular lens when shooting from a particular spot.
analog, analog lenses, camera, dslr, f-stop, k-1, k-1 and analog, k10d, lens, lenses, pentax, photography, shots
Analog PENTAX bodies vanArhcento Welcomes and Introductions 21 10-22-2022 08:48 PM
Need for help and opinions for an analog camera Sara t Troubleshooting and Beginner Help 17 08-10-2022 06:28 AM
Still Life Analog on Digital Dutch Tug Master Photo Critique 6 06-23-2022 03:08 PM
Analog in Freising, Germany p81 Welcomes and Introductions 3 08-24-2021 02:01 PM
A comparison between modern digital lenses vs analog vintage prime lenses. interested_observer Pentax SLR Lens Discussion 6 03-13-2021 02:50 AM
All times are GMT -7. The time now is 06:25 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
