Originally posted by Yyh
I have never updated the firmware (I purchased my K-1 more than 5 years ago). I did not find a need to do it, but now it looks like I have to. How long does it take to update? The instruction says to have a fully charged battery and absolutely no interruption during the update as interruption will result in an inoperable camera. This sounds intimidating ...
Old cameras that need support for new (as appeared on market after the camera) lenses are indeed a good reason...
The duration of reading the new firmware until the camera indicates it is ok (see also instructions) is several minutes, important is to wait till camera indicates ready. Never remove sdcard or battery, or start pushing buttons during this phase because you "think" it is slow, it needs to read 100% of the firmware and activate it. Patience , even if the camera is not saying much , just give’it plenty of time to finish. Go for a cup of coffee, thee or maybe a beer... unfortunately there is no progress bar on pentax camera during firmware-updates , so all you can do is wait till it’s saying ready.
The whole process, from download , copying ...etc can be done in 15 20 minutes. Might vary a bit per camera type and how quick you are in reading+following instructions . Avoid doing it when you are time constrained or stressed.., not just before your next big photoshoot, or ...
Check also size of sd card, it should be larger than the firmware: 32 MB or more.
And it is ok to load latest version at once...., it is not a problem that you missed older updates.
