Originally posted by davidsladek I think on-demand production doesn't create significant inventory, but is rather a service as you alluded to. Making it official, using its marketing to market it would make it safer and more widely accessible, I think
IR conversion is not simple UV/IR-cut filter replacement by IR filter. There are some issues that should be solved additionally:
1. Sensor assembly positioning adjustment for infinity focus.
2. Exposure measuring sensor sensitivity adjustment (should be done in camera software.
3. Anti-reflective coating of IR filter.
If you shoot IR using DSLR you should know, that auto-exposure sensor does not work reliably in different lighting situations - sometimes exposure compensation is needed to be shifret to + or to - side. Probably it depends on subject you shoot and which reflects IR light (some reflect less, some - more). So, there is some practical issues to make optimal light meter work. And this translates into user satisfaction of product.
Another and probably more important issue is sensor assembly positioning adjustment for infinity focus. What lens should be used as a reference? Different lenses focus IR light a little differently, even having same focal length. Probably infinity focus should be done for smallest focal length, but then there is possibility to get misfocus using higher focal length lenses.
If Pentax would make mirrorless cameras then IR conversion would have less issues.
Moreover I think IR camera users would like to have possibility to get straight out of camera swapped channel JPEGs to enjoy shooting instantaneously. But this is already another discussion.
