Originally posted by morepower
I'm a decades-old Pentax film user and considering the purchase of a K-1 to continue the tradition, so to speak. I know this is a loaded question but here goes. Many capable FF mirrorless cameras are available that, arguably, put the K-1 behind in terms of compactness and performance. For example, a used Sony AR7III runs about the same $$ as a K-1 ($1,500 body only) and boasts higher resolution, is about half the weight and has a wider selection of lenses. Since I'm starting fresh what do you kind folks objectively advise?
Welcome to the forum! Your post is interesting from many viewpoints. I too began in ye olden days of film, and I also mean olden. So it is interesting to hear from someone who is just now considering making such a sizable leap into the digital photography world! And by sizable, I mean really- like still using MF lenses, and no doubt MF 35mm film cameras too. So much has transpired in the interim.
As to mirrorless vs DSLR, there is much to consider in addition to weight and size. One main factor is of course the type of VF. Some have tried switching to mirrorless, only to return to DSLR use because of eye-strain caused by looking at an electronic screen depicting the reality in front of them, instead of looking through the lens at reality itself. But not everyone is so affected, at least not consciously so.
As to the weight, one must include the weight of lenses one might be interested in using. Then there is the issue of build quality. Then there is the issue of controls, handling, and features the design might afford the user that are very useful.
So, since you are coming from such a long-ago point in technology, and just now ready to jump way ahead into digital, where you'd be best off to start, with so many options available to you- to bring some enlightenment for you will certainly require knowing a bit about your photographic interests, and potential interests. Again, coming from where you are comng from, I believe you will eventually have some amazement to experience.
As to myself, I have very broad interests. Sometimes I am very interested in subject matter requiring wide angle lenses, sometimes requiring telephoto, and sometimes moderate mid-range use. Sometimes I need a lens having a wide aperture, but sometimes this is unnecessary so I can travel lighter, or use some smaller prime lenses. Sometimes it is scenics in good lighting, and sometimes I shoot low light scenes. Sometimes I need a longer FL to isolate subjects out of a scene. Sometimes I shoot action, with flash and also without.
So, what are your interests likely to be? Depending, it might not even be best for you to stick with a FF camera.
Your giving a price of $1500 for a camera of consideration tells me you might be in the US. If so, and compared to that FF camera of interest, you could get quite a deal for a new Pentax current model, the K-1 II, for not much more than that used mirrorless. It would actually be a lot more camera in many ways.
If your interests include a significant portion of telephoto use, you might consider going for a Pentax APS-C model instead. If wanting very high-level build quality and many, many useful features along with great performance, a low-use KP could be the camera love of your life. It has been known as a mirrorless killer on behalf of DSLR use, especially for high-end APS-C. Again, depends. There is a major difference as to the FOV (field-of-view) between APS-C and FF, which would make a major difference as to how things will look through the same lens. APS-C is more practical for size and weight considerations, especially when it comes to telephoto. As to going for fast (larger-aperture) wide angle prime lenses, advantage is for FF. APS-C is considered being best for all-around usage, and with smaller, lighter bodies and lenses.
