Originally posted by kayasaman It's odd that you say the fast zoom lenses are large and heavy?? I handheld my K1 with 28-105mm a few times the other day and just simply thought, this is waaaaay too light and I don't like the feel of it. The Irix 150mm I have is a little heavier but feels more solid in my hands. It just feels more meaty and better for me...
Then I could understand how it is that you are unhappy using this lens. But fast-aperture zoom lenses are indeed much heavier than slower zoom lenses, and the way I operate I prefer to avoid having to go about the way I do with weighty gear in a backpack, let alone with a tripod too. I do have some fast zoom lenses, but these are not too tele nor are they ultra-wides like the DFA 15-30mm f/2.8 lens. Avoiding weighty gear is not at all odd, since many people do prefer going with lighter carrying. For lightest kits with quality, I go with my KP, and a number of options. The most compact being some Limited primes, or often the HD DA 20-40mm Ltd and always the HD DA 15mm Ltd, and perhaps the HD DA 70mm Ltd or HD DA77mm Ltd, or maybe the HD DA 55-300mm WR. For compact quality fast lenses, the KP with Sigma 17-50mm f/2.8 EX DC HSM, and Pentax DA* 50-135mm f/2.8 and/or some fast primes. Also some longer tele lenses if needed.
On my K-1 II I have many other choices aside from my DFA 28-105mm lens, including my great old Tokina 28-70 f/2.6-2.8 Pro II which is fairly heavy, but not as much as the Pentax DFA 24-70mm, a Tokina 20-35mm f/3.5-4.5 which is a very good performer, and a number of other lenses which are of moderate size, including FA and DFA Limiteds. As you can see, my longer tele needs are relegated to my KP to keep size and weight down.
Very nice images, BTW, including your landscape shot above! I've found my FA 77mm lens has given me some very good bug and flower results also. With this lens, I prefer even more using it with my KP APS-C camera, which will put me at longer distances from the little critters to get such a shot, together with the small size of lens and camera to make for a less obtrusive presentation. But you apparently got great results, and a testiment to your MF skills!
For my early years, there was only MF cameras and lenses. I had no problem learning accurate MF technique. Much later came AF, which required some learning to take advantage of advancements it could offer. AF has since improved, but I still prefer for most of my needs, to use AF set to center-only spot focus. Then I use the shutter button half press to lock onto a certain part of the scene, a particular area having a well-defined edge and other detail for AF to grab onto, then hold down that focus while recomposing to take my shot. Due to years of MF, my eye is trained to monitor AF so I'll usually recognize if I need to employ MF override. Of course, such matters become more critical when dealing with longer tele or closeups, due to shallow DOF.
As to the DFA 28-105mm lens's performance, like any lens, for best possible results, one has to take into consideration the lens's best operating parameters of both aperture and FL. The apertures will have a narrower optimum range than is the case with faster lenses, which have more apertures available. However, this is not always the case at every point. While it is true, for example, the DFA 24-70mm f/2.8 is generally a sharper lens than is the DFA 28-105mm f/3.5-5.6 lens- yet this is not always true. The DFA 24-70mm has been shown as being not as sharp at its longest FL of 70mm, compared to the DFA 28-105mm set to 70mm and at favorable apertures. This is because 70mm is the former lens's zoom limit, while 70mm is within the latter's middle FL zoom area. Most all zoom lenses will generally be best-performing at the short-to-middle FL area of the zoom range, while some diminishment will occur when zoomed to the long end of the range.
---------- Post added 04-17-23 at 09:11 PM ----------
One prominent reason for using significant telephoto for landscapes is to compress distant scenery with less distant factors. If even the foreground elements of importance are somewhat distant, it should not be difficult to achive hyperlocal so the scene will be overall sharp. Otherwise, stopping down will be more important.
Take the sample images posted by bilybianca above, for instance. Nice shots, mostly. The first three were taken with primes, the last with a zoom lens. He lists the second shot as being taken with his A* 200mm but that was actually his 3rd shot. His second shot was actually with his F* 300mm. 300mm and f/9 is not adequate to deal with the reduced DOF 300mm brings, so not much is sharp here. Much more stopping down would have brought a better result. The last shot, OTOH, taken with a more ordinary slower F 70-210 f/4-5.6 lens turned out to be quite good. Why? Because it was shot at 118mm, in the middle FL area of this lesser class of lens, and a zoom lens at that. The aperture used of f/8 was adequate for 118mm with everything of importance at that distance looking good. Maybe it could have looked even sharper if objects were not back-lit, being shot at a different time of day- but one has to grab what is there and when. The kind of effect from this lighting could also be what one is after, and it does look good.
