Hiya, so if you look above there's a shot with a light in the middle and the moon to the left covered in mist. They were right behind me at the time. I was stood in front of that tree shielding the camera from both moon and that yellow light.
Now, having said that... one of the suggestions given to me in the astro group was related to histogram stretching. Basically the further you stretch, the more exaggerated things become.
This is a shot I did with the same lens but didn't push as far during stretching, I don't actually think I stretched the shot at all but you don't see the problem:
I'll just try stretching it now and report back my findings.
---------- Post added 05-03-23 at 05:50 PM ----------
Originally posted by photoptimist Bummer....
However, I have a hard time imagining how a Milky Way scene could create a glowing ring like that. Are you absolutely sure that there were NO other lights (street lights, house lights, head lights, flash lights) anywhere in front of or off to the side of the lens? Any extraneous light reaching the inside of the filter ring or front element could certainly flare like that. Even if the light source isn't in the frame, it can ruin an astrophotograph.
Good luck!
I'm just reprocessing that image above from my comment, but it's unlikely that anything will come out of it. The reason is that it's only a 60s exposure. The milkyway shot was 11 shots @ 60s stacked which of course means you get 11 minutes of internal reflection.
This is another example which shows the magenta ring created by light sources at certain angles:
In terms of wide field astro this was done from my back yard in the middle of one of the heaviest light polluted cities around:
Actually with the image above I think there was too much cloud to show the issue....
You can't really see much from it:
However, if we look at other images... then you do actually see the white halo:
This area was Dark! no lighting whatsoever bar the moon to the rear - if I remember correctly?
---------- Post added 05-03-23 at 06:07 PM ----------
Originally posted by Digitalis From user reports the superwide lenses from IRIX can suffer from sample variation compared to Samyang. You may have just had a bad bit of luck with this particular copy of the Samyang 24mm f/1.4 -from user reviews the lens has a solid reputation*. Using lenses wider than 20mm is ill advised for astro images due to the wider FOV incorporating more of the night sky, some stars will inevitably blur over time even with the K1 astrotracer active.
Don't overlook the Pentax DFA21mm f/2.4 Limited.
Pentax K-1 DFA21mm f/2.4 Limited
un-sharpneded 100% corner crop
* with an aggregate review score of 9.27 which puts it roughly in the same ballpark as the legendary FA31 which is no slouch optically.
By the way, I have heard this about the 12mm Irix but the 15mm and upwards should be solid. Strangely many people that I have been in contact with have told me that they had multiple copies of the Samyang 24mm then given up. It seems mainly the issue stems from decentering or optical alignment.
In terms of Ultra Wide lenses for astro.... AT kind of compounds the trailing by introducing rectilinear distortion effects meaning you get trailing primarily at the edges. I am actually wanting to work my way to a proper GOTO tracking mount then down the line dedicated monochrome cooled astro camera. The Moravian Instruments range has really taken my attention:
Products
Though in retrospect, I am told that the DFA15-30mm is actually sharper then the Irix 15mm.
One solution could be to go for the 15-30 then if I actually need f/1.4 go for a 21mm Irix.
Don't forget that these lenses will also be used for landscape too where you want wide :-)
I'll have to think about things though... ideally my thought was to get the f/2.8 zoom lineup as it's more versatile for traveling rather then lugging 50 different lenses around...
