Originally posted by pschlute
3.2 to 3.5 is 1/3 of a stop. I would be hard pressed to notice that difference in an image. Of course that assumes that the other exposure parameters (shutter speed and ISO) are the same.
Can you post some images which demonstrate the issue, and we may be able to help further.
Someone suggested looking into the custom settings. I found that for some reason (i do not recall changing anything...perhaps by accident as you suggest) the Custom settings was not set on auto...so changed that.
After testing in AUTO (green mode) and in manual, I found that I still had to move EV to 3/4 negative to get the balance I want.
I will not test the Custom Images in nature, etc.
But, for some reason I am having to move the EV slightly into the negative to get the results I want. This is not the case when the camera was new
At anyrate, I appear to be getting close to solving the issue....thanks for your input.
---------- Post added 06-22-23 at 09:06 AM ----------
Originally posted by Moby Grape
Thanks will be tommorrow before I can get back
I discovered that Custom Settings was somehow accidentally set MUTED and the White Balance was somehow set to CTE (no clue how these settings were chosen).
However, I still had to adjust EV about 3/4 step negative to get balance that I wanted. Did not have to make this change when the camera was new.
Thanks for your imput.
