Show Printable Version 150667 Likes Search this Thread
06-08-2018, 03:29 PM - 7 Likes   #16756
eaglem's Avatar
See.....it's over there!
06-08-2018, 04:00 PM - 1 Like   #16757
Mallee Boy's Avatar
QuoteOriginally posted by Erictator Quote
smc PENTAX-DA* 300mm F4 ED [IF] SDM ƒ/4.5 300.0 mm 1/400 iso1250
smc PENTAX-DA* 300mm F4 ED [IF] SDM ƒ/5.6 300.0 mm 1/400 iso250
There are many, many great images in this thread, but this set is stunning.
06-08-2018, 05:53 PM - 7 Likes   #16758
Tas
What? No motorbike?
K-1 and the Zeiss Distagon T* 2/35 ZK @ f2.
Some FYI for those shooting manual lenses with their K-1.
Back when I first started shooting Zeiss glass on my K5 I really struggled shooting wider apertures. In the end I went to focusingscreen.com and sourced a Canon S type screen. The fitted spacer for the Pentax focusing screen needed to be swapped out for one of those provided with the screen. Once I did this it made a huge difference for shooting with a manual lens. Unfortunately I had some etching done on that screen to assist framing a scene and these meant that sometimes the exposure metering would be wrong in portrait orientation. Other than this and managing to capture some annoying dust bunnies, the S type focusing screen was a bonus for manual shooting.
With the K-1 I've struggled to get manual focusing correct, even with the aid of focus confirmation. This was especially so with wider apertures on my Zeiss lenses. A few months back I bought an S type screen for my K-1. So far it's sat in its packaging up until yesterday. This was when I decided to 'throw caution to the wind' and installed it in the K-1. Just like last time, it's fiddly (even more so than the K5), susceptible to dust intrusion if you're not careful and after testing I found the spacer needed to be replaced. How did it go? Well the image above was shot at f2 and is from a walkaround I did with some Zeiss lenses to test the S type focusing screen in the K-1.
From this small amount of testing all I can say is I don't know why I took so long to do this as the difference is marked. The ability to quickly identify when a the focal point is correct has returned and from that I might need to add one more spacer to get it spot on. The difference is minimal though so I may just leave it.
A major difference with shooting using the S type focusing screen is I can quickly identify the chosen focal point as being in-focus and can shoot confidently quick because of it. With the standard K-1 focusing screen I'd be back and forth hunting the correct point and 'missing the moment' quite regularly. For me it's been well worth the stress of worrying about duffing up my camera (I didn't) and for the one bit of fluff I managed to capture (which I can live with).
The last test for now was to see if the change would be negative with AF lenses. Accordingly I also tested both manual and AF focusing on the D-FA* 70-200mm for any problems and cannot find one. Set at f2.8 focus was spot on, and in MF was way easier to see the focal point correctly. So all in all if you tend to shoot manual this is a worthwhile change to consider.
Tas
X-post with the Zeiss thread.
06-08-2018, 07:15 PM - 1 Like   #16759
Eric, superb shots, those ants looked like they were on my monitor screen, almost a 3d photo. And the last shot is simply fantastic, great detail on the bug & the flowers appear to be painted, really fine work mister tatorman.
Best Regards, Bob
06-08-2018, 10:45 PM - 4 Likes   #16760
BruceBanner's Avatar
QuoteOriginally posted by Tas Quote
Tas
Good info, thanks for that.
So then with all that, do you still get to choose the kind of Viewfinder Overlay stuff to appear on the focus screen? Like can you turn the grid lines off, AF Frame off and what not?
Oh and a couple of offerings here to keep this thread alive lol
Tourists
The Pram
06-08-2018, 11:28 PM - 12 Likes   #16761
AdrianM's Avatar
Three Laughing Kookaburras. Laughing on the inside this time!
PENTAX K-1  Photo
06-08-2018, 11:44 PM   #16762
Tas
QuoteOriginally posted by BruceBanner Quote
You can turn them on and off, it's up to you as they're not on the focusing screen.
Well done on the tourist stalking BTW.
Tas
06-09-2018, 12:54 AM   #16763
The Pram
Did you use ND filter for turning tourists in to fuzzy interesting objects?
06-09-2018, 02:15 AM - 1 Like   #16764
Mallee Boy's Avatar
QuoteOriginally posted by AdrianM Quote
That's a wall award winner Adrian.....a tourism shot for sure.
06-09-2018, 02:57 AM - 10 Likes   #16765
Hattifnatt's Avatar
Elevator selfie.
06-09-2018, 03:31 AM   #16766
https://www.pentaxforums.com/forums/attachments/190-pentax-k-1-k-1-ii/403871d1528540114-post-your-k-1-pictures-imgp0268.jpg
Schacht Ulm 50/2.8 wide open, after a bit of a clean (lens was free with edixa body because absolutely filthy)
PENTAX K-1  Photo
06-09-2018, 04:10 AM - 3 Likes   #16767
Tas
K-1 with the Zeiss Distagon T* 2/35 ZK again @ f8 capturing the enthralled family at a local 'gathering of the clans'. I suspect that's the Kerrowdown who slipped into left of frame in the pork pie hat.
Tas
06-09-2018, 04:29 AM - 4 Likes   #16768
ivanvernon's Avatar
Garden views from northern Ohio
I do not use the 31mm limited as often as I should, but always like the results even when it is not the lens best suited to a particular task. Actually, I became accustomed to the crop sensor FOV on K-3, and only gradually feeling comfortable with its wider angle aspect on the K-1.
PENTAX K-1  Photo
PENTAX K-1  Photo
PENTAX K-1  Photo
PENTAX K-1  Photo
PENTAX K-1  Photo
06-09-2018, 04:56 AM - 4 Likes   #16769
Just got a c/y zeiss 15/3.5 and it has this problem of shade coming into shot on the pentax, because the lens has to be correctly positioned, and also not quite hitting infinity yet. Still up close get very nice result; 6" focus. The daisy is very sharp at 100%.
PENTAX K-1  Photo
06-09-2018, 05:14 AM - 5 Likes   #16770
Tree and Country Road (DFA 24-70mm)
camera, copy, crop, da* 200mm f2.8, dslr, f2.8, focus, friend, full frame, full-frame, images, k-1, k-1 ii, k1, pentax, pentax k-1, pics, pm, post, post your k-1, review, sample, shots, squirrel, time
Post pictures made with your worst lens! LensBeginner Pentax SLR Lens Discussion 27 08-02-2018 10:27 AM
Post your K5IIs pictures here... SECELEE Pentax K-5 & K-5 II 2 02-21-2015 09:30 PM
There should be a post your K-30 pictures thread memo90061 Pentax K-30 & K-50 3 10-30-2012 02:06 AM
Thematic Post your winter pictures ohce Mini-Challenges, Games, and Photo Stories 10 03-22-2012 06:17 PM
Who can post pictures in the post your pictures category? Sitting Bull Troubleshooting and Beginner Help 3 12-14-2010 05:41 AM
All times are GMT -7. The time now is 06:42 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
