08-23-2019, 05:44 AM - 13 Likes   #25126
Cousins
Before Dawn
Both shot with the DFA 24-70.
08-23-2019, 05:48 AM - 9 Likes   #25127
Lotus pods
smc PENTAX-DA* 300mm F4 ED [IF] SDM /4.0 300.0 mm 1/1250 iso160
08-23-2019, 05:58 AM - 8 Likes   #25128
Hattifnatt's Avatar
I took those two sunset pictures while photographing a concert, right in front of the main stage, trying to hold the DFA 70-200 still among people dancing.
08-23-2019, 06:35 AM   #25129
WPRESTO's Avatar
Cousins .
Those little girls are just at the age when children are so charming. How many parents wish their kids could maintain that innocent delight throughout their lives?
08-23-2019, 09:38 AM - 7 Likes   #25130
Excelsior Geyser dumping in the Firehole River.
with 20mm takumar and a nd1000 during full sun around noon
08-23-2019, 10:59 AM - 7 Likes   #25131
acoufap's Avatar
K-1 DA*11-18 @ 16 pp crop 9:16
08-23-2019, 11:37 AM - 8 Likes   #25132
fs999's Avatar
QuoteOriginally posted by acoufap Quote
K-1 • DA*11-18 @ 16 • pp crop 9:16
Superb !
FF Mode • 200 ISO • Pentax DA* 200mm F2.8 ED SDM
FF Mode • 100 ISO • Sigma Art 18-35mm F1.8 DC HSM
FF Mode • 100 ISO • Soligor C/D Wide-Auto 20mm f:2.8
08-23-2019, 12:20 PM   #25133
QuoteOriginally posted by Racer X 69 Quote
Awesome!
You know I like tractors. Actually all machines really.
Like my motor grader.
K-1, Sigma 135mm f2.8 Pantel lens.
Now that's an interesting motor grader. Looks like it has miles on the odo and hours on the meter. I couldn't identify the make? Wondering about year, engine...what types of uses before and during your ownership ?
We have a lot of graders here and not just for construction use. Up here in the cold, long winter prairie, graders are used, along with front end loaders to scrape road ice, which can be frozen as hard as concrete from the roads. I know other jurisdictions...less extreme cold...use 3/4, 0n3 ton pickups, light medium duty trucks with snow plows attached, but here once we get tot the dead of winter, it seems only loaders and graders do the job.
All I can say, is thank heavens for loaders and graders.
08-23-2019, 12:28 PM   #25134
QuoteOriginally posted by fs999 Quote
Superb !
FF Mode 200 ISO Pentax DA* 200mm F2.8 ED SDM
FF Mode 100 ISO Sigma Art 18-35mm F1.8 DC HSM
FF Mode 100 ISO Soligor C/D Wide-Auto 20mm f:2.8
Really like the first flower image. Neat look with the 200.
Thanks for sharing,
barondla
08-23-2019, 12:31 PM   #25135
acoufap's Avatar
Superb !
Thank you very much!
08-23-2019, 03:31 PM - 4 Likes   #25136
eaglem's Avatar
It's sunny and I'm going for a walk.
08-23-2019, 04:44 PM - 8 Likes   #25137
Sunset at the marina.
PENTAX K-1 Mark II  Photo
08-23-2019, 05:20 PM - 6 Likes   #25138
Man With A Camera
Racer X 69's Avatar
QuoteOriginally posted by lesmore49 Quote
It is a 1948 Adams 412 motor grader. The engine is an International Harvester UD14 engine is a 461 cu.in. 4 cylinder that has 303 lbs torque at 68.5 hp. Designed to be started on gasoline, and then once warmed up switched over to diesel. Normally aspirated it has a magneto and intake manifold on one side of the engine, and an injector pump and intake manifold on the other side of the engine. The cylinder head has chambers, called starting chambers. They are exposed to the combustion chamber above the pistons via a third valve, opened and closed via a lever in the cab. Each starting chamber has a spark plug, and is the only route to the cylinders for the incoming gas/air mixture. When the starting valves are closed another linkage grounds the magneto to stop the plugs from continuing to fire when the engine is switched to diesel, and the engine then begins to run on diesel, and the machine is ready to work.
All of the functions (blade, rippers, front axle lean) are all operated via a gearcase in the cab that is powered by a shaft that exits the front of the drop box which also sends engine power to the drive axles which sit below the engine. The lever for a particular function is either pushed or pulled, and the function is operated via a train of shafts, universal joints and gearboxes. When a function reaches the limit of its movement (deadheaded) the gears the lever is connected to kick back, sometimes quite violently. One learns real quick those limits, and to ease off on pressure of the lever, or it will spank the hand.
They are affectionately knows as "knuckle busters" by the men who operated them back in the day.
It has the optional full cab, although they never had doors, and someone has added them to this one.
The machine was once owned by a company called Northwest Roads, based in Seattle. It was used for road construction during the post war growth period in this region, building roads, highways, or whatever else one does with a motor grader. The guy I bought it from bought it from a guy who had it on an island in the Aleutian chain of islands in Alaska that had a few roads to maintain. Then he used it in Gig Harbor, Washington on a private road he lived on, before I bought it to do the same here in Arlington.
The knuckle buster gearcase and levers:
Pentax K-1, Sigma 600mm f8 Mirror.
08-23-2019, 05:22 PM - 9 Likes   #25139
Crater Lake NP, with the F 17-28:
08-23-2019, 07:41 PM - 7 Likes   #25140
more old macro shots
Orange jewelweed and pink jewelweed.
Best Regards, Bob
PENTAX K-1  Photo
PENTAX K-1  Photo
camera, copy, crop, da* 200mm f2.8, dslr, f2.8, focus, friend, full frame, full-frame, images, k-1, k1, pentax, pentax k-1, pics, pm, post, post your k-1, review, sample, shots, squirrel, time
Post pictures made with your worst lens! LensBeginner Pentax SLR Lens Discussion 27 08-02-2018 10:27 AM
Post your K5IIs pictures here... SECELEE Pentax K-5 2 02-21-2015 09:30 PM
There should be a post your K-30 pictures thread memo90061 Pentax K-30 & K-50 3 10-30-2012 02:06 AM
Thematic Post your winter pictures ohce Mini-Challenges, Games, and Photo Stories 10 03-22-2012 06:17 PM
Who can post pictures in the post your pictures category? Sitting Bull Troubleshooting and Beginner Help 3 12-14-2010 05:41 AM
All times are GMT -7. The time now is 06:49 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
