02-20-2016, 11:44 AM   #16
ogl
Banned
AUTO FF APS-C and 1:1
---------- Post added 02-20-2016 at 11:46 AM ----------
My Ricoh GXR has 1:1 mode in RAW and I use it sometimes
02-20-2016, 12:32 PM   #17
Tjompen1968's Avatar
QuoteOriginally posted by redrockcoulee Quote
Draw a circle around the crop rectangle and you can clip the red square.
My bad. I was thinking out loud...
Here is a new image with the blue as a minimum APS-C image circle
02-20-2016, 12:53 PM   #18
I wouldn't be too worried about these corners in terms of coverage. The image circle of DA glass needs to cover APS-C + whatever is needed for the IBIS. Judging from composition adjustment, that's quite a lot.
So the right picture doesn't draw the circle around the APS-C crop, but rather the rectangle we can reach with comp. adjustment. That should give enough for the square.
Probably there will be some vignetting based on the lens hoods, as the lens is rotation symmetric but the hoods typically aren't. But then again, most can be taken off.
02-20-2016, 03:05 PM   #19
kenspo's Avatar
I will try to answer this tomorrow sometime
02-20-2016, 03:23 PM   #20
i83N's Avatar
Circular fisheye lens is coming?
02-20-2016, 03:47 PM   #21
QuoteOriginally posted by i83N Quote
Theta mode shooting maybe?
02-20-2016, 04:00 PM   #22
i83N's Avatar
With astrotracer?
02-21-2016, 10:52 AM   #23
QuoteOriginally posted by kenspo Quote
If you find the time... Not that I want to pressure you or anything. Ok, maybe a little pressure.
02-21-2016, 10:57 AM   #24
Banned
It's not in the spec-sheet. So maybe it didn't get to the end product.
http://www.ricoh-imaging.nl/nl/reflex-digitaal/eigenschappen/PENTAX-K-1-D-SLR.html
Maybe in a firmware update. Real aps-c lenses do not cover the 1:1 crop of 24,1 megapixels. There would be some vignetting.
02-21-2016, 11:00 AM   #25
kenspo's Avatar
QuoteOriginally posted by Gimbal Quote
Haven't had the time to test it properly..sorry
02-21-2016, 11:11 AM   #26
How should one interpret this? Pixel shift only in crop mode???
[35mm Full Frame]
JPEG: L(36M: 7360x4912) M(22M:5760x3840) S(12M:4224x2816) XS(2M:1920x1280),
RAW: (36M:7360x4912)
[APS-C size]
JPEG: L(15M: 4800x3200) M(12M:4224x2816) S(8M:3456x2304) XS(2M:1920x1280),
RAW: (15M:4800x3200)
Pixel Shift Resolution: High resolution Pictures based on the use of each Pixel for all RGB-Color Information - Now also for moving subjects.
02-21-2016, 11:27 AM   #27
QuoteOriginally posted by Tjompen1968 Quote
[35mm Full Frame]
[APS-C size]
Do not worry, this was just placed at a bad location xD.
The official Ricoh sample pictures have an pixel shift resolution sample with full 36mp resolution
Sample Image? PENTAX K-1 | RICOH IMAGING (picture at the bottom)
02-21-2016, 11:38 AM   #28
Fenwoodian's Avatar
I am pleased to hear that the new K1 full frame offers a 1:1 crop mode.
I often shoot square format. I look forward to testing some of my APS-C crop lenses on the K1 in the 1:1 crop mode. I would not be surprised to find that some of the APS-C lenses that fail to adequately fill the entire full frame sensor will do a good job at covering the 1:1 crop area.
Of particular interest to me would be how the Sigma 18 - 35mm APS-C lens covers the 1:1 crop area. Time will tell....
02-21-2016, 11:42 AM   #29
ogl
Banned
Is there 1:1 mode in reality with 1.00 firmware?
02-21-2016, 11:42 AM   #30
QuoteOriginally posted by Snakeisthestuff Quote
Puuuuh. That would have been so stupid if it would have been true. Thanks! =)
I looked at the samples on DPr and they look very promising. Also will be great to go to a pixel density lower than the K-3, i.e, back to be sloppy as with the K-5
crop, dslr, full frame, full-frame, k-1, k1, pentax k-1
Megapixels of K-1 Crop Mode rdj92807 Pentax Full Frame 7 02-16-2016 03:01 AM
K30 question about "crop sensor" and 1.5x crop mellowyeahlow Pentax K-30 & K-50 19 12-15-2014 03:14 AM
Full frame vs 1.5x Crop question at same distance richmondthefish Pentax Full Frame 15 08-20-2014 11:58 AM
645DII - 50 MP with crop 1.1. - is it good upgrade? ogl Pentax News and Rumors 58 09-11-2012 04:55 AM
1.5 crop Ric Digital Processing, Software, and Printing 9 01-08-2012 07:24 AM
All times are GMT -7. The time now is 03:18 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
