02-21-2016, 02:05 AM   #16
sfkazimierczak's Avatar
QuoteOriginally posted by raider Quote
In terms of size, the K-1 is also slightly bigger than 5D3 and a fair bit bigger than 6D too...also weigh 300g more than 6D and like 60g more than 5D3. Any idea why the K-1 has a heavier body?
It's not bigger than 5D Mark III and 6D. The only dimension in which K-1 surpasses these Canons is thickness.
"Pentax K-1 is 10% (15.5 mm) narrower and 5% (6.4 mm) shorter than Canon EOS 5D Mark III.
Pentax K-1 is 12% (9.1 mm) thicker than Canon EOS 5D Mark III.
Pentax K-1 [1010 g] weights 6% (60 grams) more than Canon EOS 5D Mark III [950 g] (*inc. batteries and memory card).
Pentax K-1 dimensions: 136.5x110x85.5 mm (camera body only, excluding protrusion)
Canon EOS 5D Mark III dimensions: 152x116.4x76.4 mm (camera body only, excluding protrusion)"
It's heavier than Canons because it's made out of better materials. As all Pentax high end cameras.
And if compare K-1 to APS-C Canon 7D Mark II K-1 comes smaller again.
Guys at Pentax know how to make gear that is compact and feels solid at the same time.
02-21-2016, 03:39 AM   #17
Digitalis's Avatar
QuoteOriginally posted by sfkazimierczak Quote
The Pentax K-1 is thicker than the Leica S by 5.5mm. Personally I can't say I have ever made that call at work when i'm switching between the S and my K mount dslrs.
02-23-2016, 06:27 AM   #18
Rickster's Avatar
I think it is heavier because of the metal on metal construction. (Magnesium alloy over stainless steel) Personally I like a heavier camera. It makes for better hand held stability. (as well as in-the-field durability) ;-)
02-23-2016, 06:42 AM   #19
Who cares! it is smaller than the 7DMKII.
Wow. That's hilarious!
I know
right?...so much for APS-C format DSLRs being compact.
Amazing, when compared like that, that's just crazy!!
---------- Post added 02-23-16 at 10:52 PM ----------
QuoteOriginally posted by HoustonBob Quote
The K1 appears to be the smallest Full Frame DSLR on the market.
Typical Pentax. Great job done.
02-23-2016, 07:08 AM   #20
Pentax did a great job on the size of the K1.
If you want to see a hilarious comparison, select the Olympus E3, that I used for a few years. Look at the sensor size.
Chris
02-23-2016, 07:14 AM   #21
Digitalis's Avatar
QuoteOriginally posted by chris mak Quote
If you want to see a hilarious comparison, select the olympus e3
HA!
You should also check out the Sigma SD1 which is a few hundred grams lighter, but physically bigger than the K-1.
02-23-2016, 08:35 AM   #22
jimr-pdx's Avatar
QuoteOriginally posted by Chris Mak Quote
Chris
Stunning. What a cute little sensor!
---------- Post added 02-23-16 at 07:38 ----------
I guess the Df is a bit smaller in the FF dSLR segment. Remember that one, anybody? What a curious mongrel mod-throwback. For somebody out there it's ideal though..
Compare camera dimensions side by side
02-23-2016, 08:57 AM   #23
aleonx3's Avatar
QuoteOriginally posted by NZ_Ross Quote
I had to check . Sucks to be a Canon 7DII owner when it come to size and weight.
Sucks to be a Canon user/owner period... I am glad I don't join the dark side... their system is so archaic (because they need to protect existing users) as everything on the camera seem so old and dated.
02-23-2016, 09:32 AM   #24
bertwert's Avatar
Impressive they could get it so small!
02-23-2016, 10:28 AM   #25
Chris
Comparing the top views is also a good reminder of why we are Pentaxians...
02-24-2016, 05:06 AM - 1 Like   #26
Two reasons. First it is packed with awesomeness. Second, you can drive nails with it.
02-24-2016, 05:48 PM   #27
Otis Memorial Pentaxian
QuoteOriginally posted by jimr-pdx Quote
Yes, Tuco seems to enjoy his. The K-1 is much thicker on account of that fancy rear LCD. If that were stripped off, the two would be much closer in both weight and dimensions. Perhaps Pentax will see fit to issue a K-1L (lite) at some later date?
02-24-2016, 10:03 PM   #28
jimr-pdx's Avatar
I presume the Super SR mechanism accounts for some of that reverse pot belly as well
02-26-2016, 06:50 PM   #29
Want a laugh? Compare the Canon 1DX or the Nikon D5 to the K-1.
02-26-2016, 08:49 PM   #30
The new fantastic multi-angle LCD contributes in the thickness while other don't
dslr, full frame, full-frame, k-1, k1, pentax, pentax k-1, pm, post, sensor, size
Selling K-3 now the K-1 has arrived? Theov39 Pentax K-3 29 02-22-2016 06:56 AM
K-s2 now on Camerasize site jimr-pdx Pentax K-S1 & K-S2 6 03-05-2015 09:17 AM
K-S1 on camerasize.com bobdobbs Pentax DSLR Discussion 4 08-28-2014 04:59 AM
Camerasize.com needs shots of your Q lenses! Tonto Pentax Q 7 08-08-2012 07:54 AM
K-01 on camerasize.com ! jogiba Pentax K-01 20 02-04-2012 11:24 AM
All times are GMT -7. The time now is 05:35 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
