Show Printable Version 9 Likes Search this Thread
02-25-2016, 12:34 AM   #46
hoopsontoast's Avatar
QuoteOriginally posted by oldfashioned_aj Quote
Which would be a good manual focus lens to have in K mount in 56mm and/or 85mm ? Any suggestions ?
Voigtlander Nokton 58mm f1.4 or the cheap Pentax K 55mm f1.8. On 85mm, good value the Samyang/Rokinon 85mm f1.4 or Pentax K 85mm f1.8.
I've used the VL and both K58/K85 and they are all excellent, the K55 stands out as its so cheap and available, the VL58 has an advantage of being an 'a' mode lens so you can control the aperture from the camera.
02-25-2016, 12:38 AM   #47
SteveM's Avatar
QuoteOriginally posted by hoopsontoast Quote
I've always found the K85/1.8 truly amazing....if you don't mind a manual lens.
02-25-2016, 01:51 AM   #48
QuoteOriginally posted by SteveM Quote
I agree, its possibly the best built lens I have handled, and so compact too. Main reason I passed it on was I needed AF for the work I do on my day job.
02-25-2016, 05:18 AM   #49
Digitalis's Avatar
it will take a year to try them all.
..you aren't the only one.
02-25-2016, 06:39 AM   #50
oldfashioned_aj's Avatar
Yes was looking for manual only. Currently I only have a spotmatic so the lenses won't go on k-1 without an adapter. Will definitely look for the K85/1.8
02-25-2016, 09:58 AM   #51
wtlwdwgn's Avatar
If you have a 55 f/1.8 or 85 f/1.8 S-M-C Takumar as I do they'll fit the K-1 with the M42 adapter. For sure I'll be testing them when I get the K-1.
02-25-2016, 08:13 PM   #52
Does anyone have any thoughts re the Samyang 14 2.8? All the reports from full frame Canon-Nikon users seems to be that it is incredible value, so now that the K1 is here it should be a good fit? Am very keen on UWA for night photography - stars, auroras. Thanks in advance!
02-25-2016, 09:14 PM   #53
FA*85/f1.4, M50/f1.2, DA*55/f1.4, D-FA100/f2.8Macro, F50/f2.8Macro, A50/f2.8Macro, DA*50-135/f2.8, F50/f1.7, M50/f1.7, K55/f2, M100/f2.8 (non-macro) in that order.
I may want to part with my DA*60-250/f4 soon.
02-25-2016, 09:42 PM - 1 Like   #54
Otis Memorial Pentaxian
clackers's Avatar
QuoteOriginally posted by LukeOB Quote
I quite like it - the absence of coma will suit your astrophotography. Here it is on my A7:
02-29-2016, 08:24 PM   #55
Try first? The FA77 of course, the most amazing "open tunnel" of glass.
But it will be nice to have the FA28 Soft and F85 Soft running at their proper focal lengths. Both had strange fields of view due to crop factor on APS-C. The K-1 might even arrive on time to be able to catch some cherry blossom shots on the Boston Esplanade this spring. (The FA28 Soft lens' target market in Japan was cherry blossoms.) The "Soft" lenses are so much easier to use when you can "chimp."
03-01-2016, 05:44 AM   #56
Caat's Avatar
My K 30mm f/2.8 and K 135 f/2.5 will probably be on there first. Followed by the 43mm ltd.
The Sigma 180 EX Macro might also get a look in shortly after.
I'm not expecting the first two to be stellar performers on such a sensor but I am hoping they both maintain their slightly magical qualities.
03-11-2016, 04:34 PM   #57
QuoteOriginally posted by micromacro Quote
Great! (offtop) What copy do you have, newest (made in Russia) or classic old (made in USSR)?
Hey, i just checked which version i have: It looks exactly like this one, but i can't see anywhere where it's from (neither Russia nor UDSSR is written on it. )
03-12-2016, 05:39 AM   #58
Nice shoot.
I've just ordered my first Samyang, a 24mm f1.4 in preparation for the K-1 as all my current wide lenses are aps-c sized.
I hope the Samyangs are good value as for once they actually suits the Pentax system in that they don't have an in lens stabilization. (Which we often have to pay for without getting it.)
03-12-2016, 05:58 AM   #59
Jatrax, why are you doing this to us, this is madness I'm jealous now
03-12-2016, 11:19 AM   #60
jamesk8752's Avatar
My three original FA Limiteds, then the DA*55, the A1.2, and the A*200/4.
dslr, full frame, full-frame, k-1, k1, pentax k-1, test on k-1
Which legacy Pentax lenses have corrections built in to the K-1? rdj92807 Pentax Full Frame 30 02-24-2016 10:31 AM
K-1: On-demand body lighting helps you see what you're doing grahame Pentax K-1 & K-1 II 26 02-18-2016 10:31 PM
How do you choose which lenses to bring? lithedreamer Pentax SLR Lens Discussion 22 02-09-2016 01:07 AM
Kx and going to a Formula 1 race - which lens? Run_Lola Troubleshooting and Beginner Help 38 06-08-2011 02:24 AM
All times are GMT -7. The time now is 01:09 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
