03-16-2016, 08:49 AM - 1 Like   #16
QuoteOriginally posted by TwoUptons Quote
Does anyone know when distance information was added to the AF lenses?
I seem to recall being told by a Pentax rep in the early 90s (about the time Nikon was going on about 3D matrix metering) that Pentax had been doing focus distance in the lenses for years.
Does that mean Pentax F lenses have distance information or is it strictly a FA thing?
-Eric
According to Bojidar Dimitrov's excellent K-mount page, F lenses do distance but FA lenses add the MTF data for the lenses and power zoom possibilities. I hope, then, that F lenses get full five-axis SR...
03-16-2016, 09:26 PM   #17
Thanks for the info. Any idea what will happen with a recent design third party lens such as the Sigma ART 35/1.4? That's the lens with K-1 I'm craving for travel and hoping it is compatible with the full 5-axis SR.
Ross
03-17-2016, 01:36 AM   #18
QuoteOriginally posted by SeattleDucks Quote
Ross
I wouldn't expect there to be any compatibility issues for autofocus lenses, so the F series and third-party lenses should be fine.
03-17-2016, 02:28 AM   #19
Fogel70's Avatar
Yes, I'm sure it seemed like a dumb question But in Pentax's official specs they stated SR was available with "compatible Pentax lenses" which made me wonder. Also, other manufacturers with a sensor stabilizer do not necessarily have full compatibility with all lenses - for example the Sony A-series with 5-axis is not available with every Sony lens - some of their lenses drop to 3-axis mode.
It will be great if the full effective 5-axis SR is available with virtually any lens.
Thanks,
Ross
I believe we will only get 3-axis of stabilization on older lenses, but on other hand those 2 extra axis of stabilization K-1 offer is only an advantage if you focus very close to the subject.
So it's only going to make a major benefit when shooting macro. Had K-1 offered mechanical stabilization during video the 5 axis stabilization would also be a benefit as the x y motion can be noticed during video.
I normal shooting condition there will most likely not be possible to notice any difference if the camera use 5- or 3-axis SR.
03-18-2016, 03:31 PM   #20
i5_david's Avatar
Why do we think we will only have 3axis?! I haven't read this anywhere... Why won't we notice the difference between 5 and 3 when Ricoh is making a big deal out of it (5 stops...). The focal distance is important? Why? I think I am having a little oroblem thinking this through (and understanding). Thanks in advanced.
03-19-2016, 05:04 AM   #21
Fogel70's Avatar
QuoteOriginally posted by i5_david Quote
The X/Y movement affect the scene as much independent of distance. If you capture a scene that is 10 m wide, and the X/Y camera shake is 1 mm, then the camera shake is less than a pixel (1 mm movement on a scene that is 10000 mm wide), so it will not affect the captured image. But if the scene you capture is 10 cm wide then the same X/Y camera shake of 1 mm will affect the scene 100 times more and will be visible (1 mm movement on a scene that is 100 mm wide).
So to know how much to move the sensor, the camera need to know the distance the lens is focused on and which focal length is used. (magnification of the shot).
(In real life the X/Y camera motion is probably much less than I described above)
Btw, the 5 stops correction is verified by using the CIPA standard test, which only apply for pitch and jaw motion (2-axis).
The number of axis compensated for does not necessarily say anything on how well the stabilization work (numbers of stops).
camera, distance, dslr, focus, focus pentax, full frame, full-frame, k-1, k1, lenses, mm, motion, movement, pentax, pentax k-1, scene, sr, test
Bracketing with Manual focus lenses mikeodial Pentax K-01 6 08-13-2014 09:08 AM
How reliable is focus confirmation with manual lenses... Knock Troubleshooting and Beginner Help 15 07-20-2014 07:30 PM
No movie SR in K3 with manual lenses Ayoh Pentax K-3 3 05-04-2014 07:54 AM
pentax k-7 SR problem with manual focus lens lwsy711 Troubleshooting and Beginner Help 4 07-17-2010 04:02 PM
Is 645D compatible with Pentax 6x7 lenses ? Samsungian Pentax Medium Format 41 04-21-2010 12:53 PM
All times are GMT -7. The time now is 11:39 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
