03-31-2016, 12:36 PM   #16
Tas
April 1st in Australia, this isn't connected is it?
03-31-2016, 12:38 PM   #17
Resident Bagpiper
bertwert's Avatar
QuoteOriginally posted by Tas Quote
March 31st here...
The manual seems legit...
03-31-2016, 12:41 PM   #18
Tas
QuoteOriginally posted by bertwert Quote
March 31st here... The manual seems legit...
Fair enough, looks too good to be a fake that or someone has WAAY too much time on their hands.
03-31-2016, 12:44 PM   #19
i5_david's Avatar
you can edit what happens when you psh the illumnation button. Now, this is intersting:
Specifying the Illumination Button Settings
You can set whether to turn on the lights for the following
camera parts when [Button] is pressed.
and now it lists different options:
LCD Panel
Backside controls
Mount
Cardslots/Connector
What is the difference between the LCD Panel (I assume the LED that are behind the panel) and the backside controls. Are the buttons itself start brighten up by pressing the button?
And: you can select the bightness of these (off, low, high)
(Manual, p. 101)
03-31-2016, 12:50 PM   #20
Big Dawg's Avatar
Manual? We don need no stinkin' manual!
Downloading right now.
03-31-2016, 12:54 PM   #21
Resident Bagpiper
bertwert's Avatar
QuoteOriginally posted by i5_david Quote
LCD Panel
Backside controls
Mount
Cardslots/Connector
(Manual, p. 101)
That would be the lights on the back of the main screen.
Like this:
03-31-2016, 12:56 PM   #22
redpit's Avatar
LCD Panel
Backside controls
Mount
Cardslots/Connector
(Manual, p. 101)
LCD panel is the small screen on top of the camera. By default if you press the light button only this small LCD panel is illuminated...
03-31-2016, 12:58 PM   #23
i5_david's Avatar
What a sexy Camera you have there, mate
What illuminate the backside controls option then?
I imagine that these light will be a blast when shooting nightsky or landscape at night. Aahhh I want mine too
Ah ok. This makes perfectly sense. Thanks for clarification. Lcd on top.
03-31-2016, 01:00 PM   #24
Resident Bagpiper
bertwert's Avatar
Not my photo, borrowed from somewhere on the internet.
That IS the backside illumination.
03-31-2016, 01:03 PM   #25
Tjompen1968's Avatar
Sooo... I have read it from start to finish and I find some changes in the menus really smart. It will take some time to adjust from the K-3. Hitting playback will start Live View on the K-1. I wonder how many times I will do this before I learn I will love to customise the Info menus and remove all clutter that I do not use.
The only thing I will miss when using the K-1 is the larger LCD. I will miss not seeing how much space is left on the card, the metering mode and drive mode but I guess I will get used to it.
03-31-2016, 01:46 PM   #26
Otis Memorial Pentaxian
QuoteOriginally posted by Tjompen1968 Quote
By tilting your camera down and moving the sensor up you have the possibility to compensate for the keystone effect. Not as much as a shift lens but to some degree.
Yep...It is hard to describe how it works unless you actually have a shift lens mounted or have access to a view camera. Keystoning is simply the laws of perspective as they work out within the image frame. With a rectilinear lens, if the lens axis is perpendicular to the subject plane, parallel lines stay parallel. Tilt the lens upward and lines will converge to the top of the frame. What composition adjust allows you to do is to leverage the unused sensor area outside the frame to make it possible to "see" just a little more of the top of a building, tower, or tall friend without tilting the camera.
This diagram shows how it works:
as does the page I stole it from:
http://cow.mooh.org/projects/tiltshift/howdoesitwork.html
In short, the camera shifts the sensor downward to "see" more of the subject top without having to tilt the lens. This approach works well within limits of unused sensor real estate and the image circle of compatible K-mount lenses. A true shift lens has a large image circle and moves the lens axis rather than the sensor to get the same effect.
03-31-2016, 01:53 PM   #27
i5_david's Avatar
thanks. I get it a bit (i guess ) but I think it will be easier, when I have my camera and can try this effect self and see the difference it can make (even these few pixels).
03-31-2016, 01:57 PM   #28
QuoteOriginally posted by jandersson Quote
Hope this explanation will help: K-7 What is CTE? | Ricoh Imaging Support
/Jan
QuoteOriginally posted by filoxophy Quote
CTE accentuates the white balance shift rather than correcting for it, if you want your pictures to look warmer or cooler. That's my understanding--never used it.
Thanks! I forgot that Google is my friend
03-31-2016, 02:30 PM   #29
monochrome's Avatar
Charging tablet now . . .
03-31-2016, 02:31 PM   #30
Looking through for changes from the K3. Other than hardware of course.
p65 you can change flash level compensation from the body. Does the K3II do this?
FX1 and FX2 buttons have a selection of functions, SR on/off, horizon correction, level, file format, flash mode(probably pops up a selection), pixel shift. Nice.
The 5 user modes are nice, and the third dial will be handy.
Generally a K3 shooter will be able to pick it up and start shooting. Then start learning the finer points.
camera, canon, capabilities, dslr, firmware, full frame, full-frame, gps, image, issues, k-1, k-3, k-5, k1, nikon, pentax, pentax k-1, people, players, pm, quality, sony, video, videos
K-1 user manual availability? JBox Pentax K-1 17 03-10-2016 05:12 AM
For Sale - Sold: Sigma 50mm f1:2.8 K-A Mount 1:1 Macro Manual Focus Lens $85 shipped to US Archimedes the Dog Sold Items 7 11-28-2015 09:46 AM
For Sale - Sold: M-50/1.7 M-50/1.4 K-55/1.8 M-40/2.8 Manual Primes AquaDome Sold Items 5 12-22-2014 08:06 PM
Reversing Ring for Pentax K Manual Focus Lenses only CDN$ 1,192.85 SointulArt Pentax Price Watch 13 11-22-2014 10:43 AM
All times are GMT -7. The time now is 04:04 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
