04-09-2016, 02:32 AM   #31
clackers's Avatar
QuoteOriginally posted by noelpolar Quote
Yes, the K-1 could be marketed as a "Special assistance Camera" , for those that can't bend (floppy screen), see all that well (led lights), hold things steady (5 axis), forget where you are/were (GPS), have fits (flash removed), have compulsive collecting disorder (old K lenses) etc etc....
LBA should be in the DSM. ☺
04-09-2016, 02:52 AM   #32
Turned 50 so this sounds like an investment. Only GPS is a waste of resources as people older than 50 may actually have learned map reading. Rather have the pop up flash as at 50 , I am more likely to forget to bring a flash unit.
Maybe a K-1 sr for the older people who know how to readmaps but forget the flash and a K-1 jr for those who are used to rely on GPS?
04-09-2016, 02:57 AM   #33
There are a hell of a lot of photos I wished I could have geotagged; I can't be sure anymore about exactly where I took them, and would like to go back one day. And if it will, as I have read, also tag the direction the camera is pointing, it should be valuable for forensic and criminal investigators, who will be able to demonstrate in court when and where they were and which way they were pointing when they took the shot.
04-09-2016, 03:26 AM   #34
noelpolar's Avatar
Not sure how reliable the "what direction you were facing" is.... most GPS's need you to take a couple of steps before giving an accurate bearing.... or am I using old GPS's?
04-09-2016, 03:36 AM   #35
IIRC the camera has a compass function also.
04-09-2016, 05:01 AM   #36
It does have a "normal" electronic compass as well, which needs to be calibrated now and then.
But the GPS direction of movement (and speed) is also recorded, so if you take pictures from a boat (for instance) the speed and direction of travel plus the aim of the camera (inclusive degrees up/down and tilt) is recorded.
04-09-2016, 05:06 AM   #37
It records the tilt and azimuth as well? Then a little bit of trigonometry will pretty much give you exact location, including distance to the action - just photograph the feet.
Indeed it really is the perfect police/crime scene camera. We need to push this to the TV studios so they can work it into their scripts, as well as to medical examiners, forensic pathology laboratories and police departments.
04-09-2016, 06:41 AM   #38
MadMathMind's Avatar
QuoteOriginally posted by pathdoc Quote
They look like something from Lovecraft, coming out of the water with all the mist in the near-dark...
With all the screaming that gets done about diffraction setting in at f/11 or even lower, why do so many Pentax lenses of both older and more current vintage go to f/32?
You couldn't change film. If you had ISO400 film in there because you were shooting inside and wanted to shooting something outside in bright daylight...think of it this way: ISO100 at f/8 = ISO400 at f/32
Sharpness was less a big thing back in film era since most of the photos you were viewing were 4x6 or on a mediocre projector (slides).
04-09-2016, 07:14 AM   #39
Yes it does record tilt and azimuth. Don't know if it would work as a crime scene camera though as the numbers can be totally wrong now and then, even if it does work most of the time.
There is some cool software (which name I don't recall right now) which not only displays the position from the GPS coordinates on a map, but also draws a cone from that position in the direction recorded by the compass, and the cone width depends on the focal length used. So everything in the cone should be in the frame of the photo.
04-09-2016, 08:36 AM   #40
loveisageless's Avatar
LOL. Yes the first ADA approved adaptive full frame camera. They may be on to something! Retired baby boomers with disposable income and time to travel may be a potentially huge untapped market segment🙂 I already appreciate the option to enlarge the font for the menus and rear LCD.
04-09-2016, 12:00 PM   #41
QuoteOriginally posted by loveisageless Quote
My knees aren't so bad, but the hereditary hand tremor is. The five axis stabilization may be the deciding factor
A friend who has a mild Parkinson's tremor shoots Nikon stabilized long lenses with great results.
dslr, full frame, full-frame, images, joy, k-1, k1, pentax, pentax k-1, photography, photos, wait, weekend
Landscape Wait for the next day David Cardoso Post Your Photos! 4 11-29-2018 08:52 PM
Machinery The evolution of the threshing machine RGlasel Post Your Photos! 4 02-28-2016 12:31 PM
Can't wait much longer for the FF ClinchShots Pentax Full Frame 84 03-27-2015 05:05 AM
A post-processing dream machine? George Lama Digital Processing, Software, and Printing 3 01-28-2009 05:02 AM
My K1D dream machine for the end of 2008 RaduA Pentax News and Rumors 34 01-30-2008 11:15 AM
All times are GMT -7. The time now is 08:28 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
