04-11-2016, 01:52 AM   #1
K-amps's Avatar
K1 Remote release connector
Hi Everyone.
Since the K1 will be my first Pentax DSLR, I have a question all Pentaxians would hopefully be able to help me with (I did not find the anwser in the Manual)
What sort of connector does it use for a wired Cable release. Is it a 3pin like the canons or the headphone type jack?
I want to order a remote that can handle Bulb, Normal shutter release, intervalometer etc. What should I order?
Thanks you all,
K-amps
04-11-2016, 02:04 AM   #2
pjv
Otis Memorial Pentaxian
pjv's Avatar
QuoteOriginally posted by K-amps Quote
Pentax CS-205 Wired Remote reviews - Pentax Camera Accessory Review Database
This is the one for you !!!
04-11-2016, 02:11 AM   #3
K-amps's Avatar
Thanks buddy. So its a headphone type 1/4" connector.
Its close to $40 on BH and $50 on Amazon. That's quite a lot for a simple cable release.
04-11-2016, 02:18 AM   #4
pjv
pjv's Avatar
The Pentax one is dearer than the " no-name " branded ones, but I have had both and found the cheapies to be less sensitive, harder to half press to focus without releasing the shutter.
Good luck with your K-1 !!!
04-11-2016, 02:36 AM - 1 Like   #5
Tas
I use a wired remote with my K5, it uses the same connector as the K1, it is this one: Canon RS-60E3 Remote Switch 2469A002 B&H Photo Video
It doesn't have a lot of control options so I've ordered one of these: Vello ShutterBoss II Timer Remote Switch for Canon RC-C1II B&H
The Canon sub mini is the connector to look for if you want to seek cheaper options like this one: http://www.bhphotovideo.com/c/product/765659-REG/Vello_RS_C1II_RS_C1II_Wired...981&
04-11-2016, 02:55 AM   #6
K-amps's Avatar
QuoteOriginally posted by Tas Quote
The Canon sub mini is the connector to look for if you want to seek cheaper options like this one: Vello RS-C1II Wired Remote Switch for Select Cameras RS-C1II B&H
Thanks guys!
I think I will order the Vello shutterboss wired.
04-11-2016, 03:03 AM   #7
An intervalometer is built into the K-1, so you may not need to worry about getting an external one.
The other remote functions you mention can also be handled via IR remote. The K-1 has IR receivers at the front and the back of the camera. Compatible Pentax IR remotes are available for about $5 on eBay.
04-11-2016, 04:46 AM   #8
UncleVanya's Avatar
1/4" ? I don't think it is that large. That is the size full size headphones used in the 70's and guitars use today. I think it is either 1/8" or even smaller.
04-11-2016, 04:47 AM   #9
K-amps's Avatar
What about Bulb mode shutter release?
04-11-2016, 04:49 AM   #10
joergens.mi's Avatar
But you may have problems with the IR-Remotes, when you are not standing in Front or behind the camera, all my cameras K20D K5 K3 may have problems when you stay aside the camera. And the SR will be switched off by IR-remote
For bigger distances I prefer wireless remote controls Cactus V5 Yongnuo RF 603. otherwise i use cheap cable remotes, both of them do not disable camera SR.
04-11-2016, 05:55 AM   #11
i83N's Avatar
You can use your smart phone as cables releases with trigger trap kit, plus you can use wi-fi for remote function
04-11-2016, 06:05 AM   #12
IR remotes work for bulb mode shutter release too. There are 2 modes in Pentax bodies. Mode #1 where in you keep the button pressed for the time you need the exposure and release it. Mode #2 where you have first press opening the shutter and the second press closing the shutter. IR remotes work very well with this Mode #2. With Mode #1 not so much as it needs to keep transmitting the signal to keep the shutter open and this may be interrupted very easily as the communication is only in the line of sight.
But I use Mode #2 almost always when I need buib with IR. And there is an IR App in case you hahve a phone equipped with an IR transmitter. Some Apps also offer intervalometer. But I would use Pentax's built intervalometer in a heat beat.
From what I can tell you don't need a shutter release if you can use an IR app. Also if you are thinking to have a remote shutter release just to avoid camera shakes then you can also use mirror up (or a 2 sec timer shot on some bodies) instead of remote shutter.
04-11-2016, 06:17 AM   #13
Check your phone, it may have IR capabilities. There are apps that work very well.
The plug is the very small jack, 2.5mm I think. It is smaller than the normal headphone jacks, and was common on phones a few years ago.
04-11-2016, 06:44 AM   #14
UncleVanya's Avatar
Why on earth would you WANT SR to not be disabled in any situation where you are using a remote?
04-11-2016, 07:23 AM   #15
I make photos in old buildings with wooden floor and lot of visitors, there it is more than usefull to have sr on a tripod.
Have you ever done photos from a bridge with a lot of traffic?
connector, dslr, full frame, full-frame, k-1, k1, k1 remote release, pentax k-1, release
To K1 or not K1 - that is the question? interested_observer Pentax K-1 78 07-15-2017 03:58 PM
Pixel Shifts' Impact on the K1 Shutter Release life-span Fenwoodian Pentax K-1 25 03-26-2016 12:47 PM
Which Remote shutter release? sarge Pentax Camera and Field Accessories 16 03-24-2016 05:44 AM
Wired Remote Shutter Release C_Jones Pentax Camera and Field Accessories 46 02-23-2016 06:30 PM
TriggerTrap Mobile + IR Remote = App driven remote shutter release RoyT Do-It-Yourself 4 01-02-2014 08:50 AM
All times are GMT -7. The time now is 04:59 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
