05-03-2016, 10:56 AM   #91
fs999's Avatar
How is the 150-500 on your K-1?
Freezing the K-1.
I have found a way to take one photo : I release a little bit the lens, turn the lens on MF and the K-1 on. Then I try to manual focus and just before shooting I lock the lens back...
05-03-2016, 01:35 PM   #92
QuoteOriginally posted by fs999 Quote
Freezing the K-1.
Insulating the data pin on the mount might also work. No AF, but at least you would be able to use the lens.
05-03-2016, 09:28 PM - 3 Likes   #93
Enigmaticca's Avatar
You are right, but so is Ptitboul. Read his comment carefully again.
Noted thank you.
My K-1 arrived this morning. It is with much relief that I can report that the following Sigma lenses works perfectly:
  • 17-35mm F2.8-4 EX DG - "3 44" (Generic Sigma)
  • 24-70mm F2.8 IF EX DG HSM - "8 255" (Generic Sigma)
  • 70-200mm F2.8 EX DG Macro HSM II - "8 16"
  • 50-500mm F4.5-6.3 DG OS HSM - "8 17"
  • 35mm F1.4 DG HSM - "8 29"
05-03-2016, 10:00 PM   #94
QuoteOriginally posted by Enigmaticca Quote
Very good to hear!, since I have those two Sigma's.
Maybe the Oz Sigma's have newer firmware that the others we've heard about in this thread.?
Now I'm running out of excuses for delaying my K-1 order ...
05-03-2016, 10:27 PM   #95
No excuses now!
My 50-500 came locally from CR Kennedy but both the 35 ART and 70-200 from O/S.
05-03-2016, 11:43 PM   #96
Class A's Avatar
Is there anyone with a Sigma 100-300/4 EX and a K-1 who can check compatibility?
I'd like to run out of excuses as well.
05-04-2016, 09:32 AM   #97
My K-1 arrived this morning. It is with much relief that I can report that the following Sigma lenses works perfectly: (...) 24-70mm F2.8 IF EX DG HSM - "8 255" (Generic Sigma) (...)
That is suprising. The hypothesis was that the "8 255" sent by the lens was the reason that made the K-1 freeze.
It appears to be more complicated, and therefore it is something else sent by the lens.
I hope that Pentax engineers will be able to fix the bug of having the K-1 freeze when receiving non-compliant data, but I am less optimistic now.
05-04-2016, 10:56 AM   #98
geko5766's Avatar
Sigma 24-70mm / 70mm macro
Hello,
we could test the two lenses today on another body and both worked smooth on this body.
However we remarked that I have a certain free gap on the mount of 1/10th mm and both lenses are not as tight on my mount as on the other.
Could someone who has a similarproblem test if the leses are also a liitle more loose and not completely tight.
I contacted Pentax Germany to ask how to proceed further as all other of my lenses ( +20 pcs.) work fine.
Best
Georg
05-04-2016, 11:04 AM   #99
UncleVanya's Avatar
QuoteOriginally posted by Ptitboul Quote
I think the only 8 255 lenses with problems have all been 70-200 f/2.8 models. The problem may be the two things taken together as the body knows the focal length of the lens and this ID. The other 70-200 f/2.8 identifies differently.
05-04-2016, 02:41 PM   #100
And the Sigma 150-500mm F5-6.3 DG APO HSM belonging to fs999.
05-04-2016, 02:49 PM   #101
UncleVanya's Avatar
Whooops! Missed that one.
05-05-2016, 07:48 PM   #102
UncleVanya's Avatar
https://www.pentaxforums.com/forums/172-pentax-k-3/320369-k1-freezes-sigma-24-70-ex-dg-hsm.html
Another lens issue.
05-05-2016, 08:36 PM   #103
Another "8 255" lens, though some identify as "8 7"
05-05-2016, 08:39 PM   #104
UncleVanya's Avatar
The plot thickens.
So can anyone explain what the reason for reusing the same number is? Are there just not enough numbers for the number of lenses?
05-05-2016, 10:50 PM   #105
Big mystery...Sigma has a history of doing this as does Tamron and Tokina. In some cases the lens id is the same as a Pentax lens at the same focal length. My Sigma 50/2.8 EX DG macro identifies as "3 41", the same code used by the Pentax-F 50/2.8 macro.
af, aps-c, business, camera, dg, distance, dslr, fees, full frame, full-frame, hsm, k-1, k-1 3rd-party lens, k1, lens, lenses, market, mine, pentax, pentax k-1, scale, sigma, technology, version
For Sale - Sold: K/M/A 3rd Party, 1 Zoom, 5 Primes, 3 TCs, 3 Ext. Tube(s), Sigma, Vivitar, Adaptall-2 MightyMike Sold Items 56 12-27-2015 10:34 AM
For Sale - Sold: K/M/A 3rd Party, 3 Zooms, 4 Primes, 2 TCs, Series 1, Sigma, Ricoh, Kiron, Lenbaby MightyMike Sold Items 18 04-07-2015 05:27 PM
K-50 with 3rd party zoom lens rumplestiltskin Pentax K-30 & K-50 5 01-13-2014 10:14 AM
K-X and 3rd party lens - need help YodaRules Troubleshooting and Beginner Help 3 03-30-2013 11:04 AM
3rd party lens compatibility with K7 Rush Pentax SLR Lens Discussion 7 08-21-2010 02:11 PM
All times are GMT -7. The time now is 03:50 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
